HPA-9's variable gain slider.
0 Members and 1 Guest are viewing this topic. Read 819 times.
Genez
« on: 5 Jul 2017, 11:23 pm »
The HPA-9's variable gain slider?
The slider...   Does that effect only the headphone level?  Or, will it also effect the output level to an amplifier?
If I want to use the HPA-9 in the the preamp mode? How should it be set?
I tried finding an online manual, but there was none I could find at this time.
Thanks...
John Casler
Re: HPA-9's variable gain slider.
« Reply #1 on: 6 Jul 2017, 12:36 am »
Thanks...
I think you are looking at the HL and LL Headphone Switch.  It is not a variable gain slider.
I think it only affects the Output to HeadPhones, but I don't have one here to test.
It is for High Level and Low Level Gain for the Headphones.  It is a selector type switch.
I do have a copy of the manual and this is what it says:
Gain Selection
High gain & low gain selection switch.  Select the desired gain setting to fit your earphones and headphones spec.
Genez
« Reply #2 on: 6 Jul 2017, 01:57 am »
Thank you, John...
Awaiting delivery as I type.
