DC offset and mechanical transformer hum
0 Members and 1 Guest are viewing this topic. Read 2533 times.
jostber
« on: 5 Jul 2017, 02:15 am »
Has anyone tried a DC offset unit like this from Kemp to handle transformer hum? I wondered to check if this would work for a 211 amp with some mechanical transformer hum I have.
http://www.kempelektroniks.nl/en/231...c-x-terminator
Speedskater
  • Kevin
Re: DC offset and mechanical transformer hum
« Reply #1 on: 5 Jul 2017, 03:20 am »
Does it hum 24 by 7 ? How about in other buildings? How old is the unit the transformer is in?
DC offset is well down my list of causes.
jostber
« Reply #2 on: 5 Jul 2017, 10:47 am »
The amp hum is quite low through the speakers, but you can hear the transformer humming (like a low buzzing sound) when getting close to it. This amplifier is about 5 years old and  is working great except this. The transformer is quite massive for this amp.
I also have two Bob Carver 180 Monoblocks in the same location, no hum from these at all.
timind
  • permanent vacation
« Reply #3 on: 5 Jul 2017, 11:51 am »
I'll ask the obvious. Have you made sure the transformer's bolt is tight? Tightening the bolt worked for me once.
jostber
« Reply #4 on: 5 Jul 2017, 12:02 pm »
I will check that, but I believe this must come from the transformer itself.
sfox7076
« Reply #5 on: 5 Jul 2017, 06:44 pm »
Hum through the speakers would not be the same hum as the mechanical hum of the laminates.  I have a 300B amp that has some mechanical hum on the transformers, but no hum in any other form.  The DC offset hum or mechanical hum is the laminates in the transformer shaking. The hum through the speakers is a signal issue.
WireNut
« Reply #6 on: 6 Jul 2017, 03:20 am »
If you or a friend like DIY there are a lot of options for adding / building your own DC Blocker.
If your not into DIY then Audio by Van Alstine offers a pre-built unit "The Humdinger" and ATL HI-FI also has a pre-built unit.
http://www.avahifi.com/products/humdinger-dc-line-blocker
http://www.atlhifi.com/shop/fully-assembled-devices/dc-blocker-trap-filter-assembled-in-case/
For pre-build DIY units to add to your amp or for just the circuit boards with build instructions look here:
http://sjostromaudio.net/shop/mains-circuits/60-dct02-dc-filter-for-toroidal-transformers-built-unit.html
http://www.atlhifi.com/shop/populated-pcb/fully-populated-dc-blocker-pcb/
jostber
« Reply #7 on: 6 Jul 2017, 07:39 pm »
Thanks for the feedback, I will check more this weekend and report back.
