0 Members and 1 Guest are viewing this topic. Read 2492 times.
I have plugged Laptop, DAC, and Amp all into same Non-Grounded outlet...
Thank You, for music I'm just using a laptop (foobar), to DAC, to integrated amp with passive speakers.No TV cable or anything else. It sounds perfect until I unplug the laptop plug in the Laptop power cable
Laptop PSU's tie the SMPS ground to safety ground (earth). It is a loop. The problem is its a filthy loop.I would make a box with in and out plugs, and use a Schurter DENO on the ground. You could use a metal outlet box, 2ft 12ga cord, two marinco ends. Connect safety ground to the box and DENO at thr same point, and then connect the DENO to the output safety ground. You don't even have to strip the hot/neutral inside the box at all, just do an open-ground surgery. That is how I'd do it, but maybe you can find a premade one?
I just went and bought a grounded ext. cord. plugged that into laptop. Problem resolved. Very happy.Doesn't matter what the amp or DAC are plugged into, all noise is gone.naturally the closest grounded outlet is 50ft away.Breaker box is 30ft-40ft away, but in a good location. I can have an electrician run a grounded wire to grounded outlet. I think it would EZ-PZ to run the wire. You can see the backside of the wall to my main listening room in the basement. And I plug in my equipment to the wall you can see. With a flashlight you might be able to see the actual outlet. It's under some storage shelves. Really hoping it doesn't cost too terribly much to run a 30ft-40ft grounded wire from breaker box to grounded outlet. Any suggestions appreciated Thanks All !
It's not the ground, it's the loop area that may be the problem. But ground loops are about low frequency hum & buzz, not hiss, noise & static.Getting all the involved 3 wire chassis's connected together with short heavy wires is a good first step.The 2 main problems are:1] Internet, cable TV and remote PC's that are grounded elsewhere.2] Poorly designed audio input connectors.* * * * * * * * * * * *While hiss, noise & static may be poor shielding or other interference problems.
My Cheap and Cheerful solution for now is running 3 prong extension cord from washer/dryer area to the Ethernet/cable TV outlet behind listening room.
The Cable TV cable is completely separate from everything else. Just goes to DVR/TV box for TV. I don't have it hooked to my main audio system in any way. Power for TV and DVR/TV box are separate too. This is not my main movie room so it's just the TV speakers for TV audio in this room.
So are you saying they are not plugged into the same AC outlet as your audio only system.They are fed from an entirely different branch circuit.
So why? What possibly could the addition of the equipment ground be doing to solve the OP's noise problem? Could it possibly be draining off any AC leakage that may be present on the chassis, from a power transformer, of a piece of equipment back to the main service neutral in the electrical panel? Thus putting the AC leakage on the chassis at zero potential with respect to the service neutral conductor? We both know it has nothing to do with mother earth.......................
