The Nimbus speakers are incredible!
0 Members and 1 Guest are viewing this topic. Read 4580 times.
ctsooner
Re: The Nimbus speakers are incredible!
« Reply #20 on: 24 Jul 2017, 01:55 pm »
Steve, which Hz are you using to diffuse the sound around the TV?  Thanks
audioengr
« Reply #21 on: 16 Sep 2017, 08:28 pm »
These are quarter-round tube traps from ASC in Oregon.  They act both as bass traps and scatter the backwave to improve imaging.  You can actually tune the image with these.  I bought them used, so I'm not sure of their specs.  Not that critical, just need the round surface to go next to the flatscreen.
Steve N.
ctsooner
« Reply #22 on: 17 Sep 2017, 09:12 pm »
Hope you are doing good.  Thanks for the update.  I am probably going to buy some 45" tall silk plants to put in between the speakers/tv first.  Then figure it out from there.  I have a spec of glare from the screen (I cover said screen and it's gone).  I do have a few question on the server though.  Let me know if I can call one of these days.  Thanks.
It still sounds better than any computer based server I've auditioned.  ;)
