What does 3D music sound like and its difference from stereo music?
0 Members and 1 Guest are viewing this topic. Read 3751 times.
George Jackson
Just wondering.
Is an SST Trinaural Processor a 3D music generator?
Thanks.
Bruce
  Hi Bruce, it has nothing with a trinaural processor. i had bought one since I found this. It was just an in-ear binaural microphone called Scenes Lifelike which appears as same as common earphone shape. But it comes with a Digital Box that one end of it has a lightning interface for iOS devices. It was said that certified by MFi, so only using iPhone plug in and go. Very simple to use, and since it works as earphone too, you can experience the binaural audio immediately after recording and sharing. The device just uses iPhone for power and storage, also supports other live app like periscope and livestream etc.
George Jackson
Two channel set up properly with the right components can give you 3D sound staging and imaging or in my case 4D. BSG QOL anybody !
charles
hi charles, do you mean the speaker playback sound system like Dolby 5.1?
George Jackson
Abbey Road studios mixed Pink Floyd in 3D audio for their London exhibition, listen to how the engineers describe it in this video. I have the same speaker layout (also with active speakers) in witchdoctor studios  :green:
https://youtu.be/yMlFN8V4qW4
wow, this is very enlightening!THANK YOU
