0 Members and 1 Guest are viewing this topic. Read 4680 times.
Thanks Anand.I want a single enclosure to house all 4 channels so the Ghents are out, otherwise they would have been an obvious choice. Good to know that Modushop have a US importer - will email them. The Landfalls are just trays, good for valve amps but not quite suitable for the Ncore.I like the Takachi HY series but have been unable to find a US supplier. Do you know of one?
They are much more sturdy than the Par-Metal enclosures I've used in the past. You can probably find them in different sizes to suit your needs. Front Panel Express will engrave any SVG image you supply (in fact, I think they now do multi-color laser printing).p.s. You might try seeing what you can find at DIYAudio if you haven't already. The crowd over there tends to be more tech-savvy.
I take it then that the B3209A case is not really large enough to accommodate four channels.
Al2002,Lowtech is right, diyaudio is more of a technically savvy forum, you should get more responses there. Takachi does not have a US distributor, their enclosures are very pretty and sturdy, used by numerous high end manufacturers. For me, since the NCORE units have their own integral heatsinking, I would use the Slimline series from Diyaudio/Modushop which have countersinked screws for a clean look appropriately sized for my (4) modules and be done. You can do all the engraving/laser you want with Front Panel Express. It's not rocket science, but it's fun for some of us At least with enclosures, if you throw money at it, you'll get a nice looking solution!Best,Anand.
Hi jtwrace.Yes I've seen the Hypex Circle. Shame it is no longer active. Anyone know why?
I think the round NC400 modules are too tall to mount directly to the heat-sinks of that chassis.Dave.
