0 Members and 1 Guest are viewing this topic. Read 13993 times.
My understanding is that two stereo cardioid subs would have better spatial resolution than the distributed monopole subs, assuming the latter are all receiving the same summed mono signal. How far that carries over when we have left and right channel signals going to the respective left and right pairs of monopole subs, I don't know.
AJ,As I try to read up on gradient/cardioid in-room bass effects it seems that stacking out of phase subs and a delay (perhaps 4 ms) applied, with one pair per channel is the practical ideal to achieve the effect (for non-amplied music). True?
And is it not true that the cardio effect is only about 10 dB and that overall it reduces output significantly?
Anand, I should be clear that there is no one size shoe that fits all. There are dipoles and cardioids than extend to below 20hz and may prove all one persons needs for bass. The fact is monopoles are simply more efficient in this area and there is no real benefit to gradient output in this region below 40-50hz, or non-mono reproduction.But a very common misunderstanding is that gradients are less efficient than monopoles. This is false. Above F equal, they are more efficient. So it all depends on what frequency F equal is in the system.The other issue regards both spatial reproduction and localization. Multiple subs can indeed yield smoother amplitude response, but that is limited to around an upper end of about 80-90hz, due to localization. There are lots of modal issues above this, in typical rooms, up to several hundred Hz, typically around 400hz or so.Multiple subs are useless between 90-400hz. Most folks then resort to both EQ and/or so called "treatments", but these have there own issues.Gradient systems can address issues in this region where monopoles by themselves, cannot.Yes It's the best $125 spent in audio, if that is ones interest.cheers,AJ
Hi skvinson,A combination of DSP and multiple bass sources is probably better than either one alone. Imo DSP alone is not as effective as multiple subs alone for smoothing out the modal region over a large listening area, but DSP alone can do a very good job in a small listening area. Personally I'd prefer only having DSP in the signal path to the subs, and not in the signal path to the mains, but that's just my personal prejudice.
I agree - multiple subs are great at evening out room modes, especially the ones created by the front/rear walls and the side walls. Floor/ceiling tends to NOT be addressed by multiple subs, and DSP is a good option to knock that mode down.
Why can't subs be mounted above the room centerline? Yes, aesthetics is a concern for some but if you are already doing multi-sub then you should do it right. Your room is 3D so you should think about trying to energize as many room modes as possible throughout the space. Keeping all subs on the ground is not optimum as Geddes has shown.
