Best (smooth and clear) sounding bluetooth speaker???
0 Members and 1 Guest are viewing this topic. Read 10720 times.
ebag4
Re: Best (smooth and clear) sounding bluetooth speaker???
« Reply #60 on: 12 Mar 2018, 09:52 pm »
Hmmm, yes, thanks for posting, this has been on my radar, but I’m seeing $149.00 for the current deal with the case?  :scratch: not that $20.00 is a deal breaker, but $20 bucks is $20 bucks...
That is what I am seeing now as well, I went to my order and pulled up the same seller, his price is now $169 for the speaker and bag.  I guess I lucked out with the timing, sorry guys.
If your budget stretches to $300:
https://www.ikmultimedia.com/products/iloudmm/
Thanks Russell, but I was looking for something portable with good battery life.
Best,
Ed
Russell Dawkins
« Reply #61 on: 13 Mar 2018, 06:31 am »
Best,
Ed
With that criterion and with the budget you mentioned, I would go either for the Denon Envaya DSB-250 (only, not the 150 or any other model), about $200 or the Vifa Oslo or possibly Vifa Copenhagen, the latter two being $450-$700 or so, but able to play stupid loud and clean, like a decent component system. Even with $1000 to spend I would go with the Denon because the midrange tone sounds better to me in all the comparisons I have heard on Oluv's detailed reviews and I don't need loud and the field is advancing very rapidly over the last couple of years. He uses binaural mic setup, so you need to use headphones:
https://youtu.be/FLKKBdPkDHM?t=1
According to this 17 day old review by "notanaudiophile":  https://usa.denon.com/us/product/portableaudio/bluetoothspeakers/envayadsb250bt
the Denon may not yet be available in the USA—but they are in Canada, but not easy to find and they cost $325CAD
With all this talk of the Riva Turbo X, I should say that I have one that I have played for a total of 2 hours from new and want to sell, but I'm in Canada, so it makes more sense to sell it locally; shipping could be too big of an expense. I want $125CAD for it. Sounds wonderful, but I'll bet the Denon sounds better and is way smaller. As I say, pace of development in this field is white hot at the moment. I'm in Victoria BC.
mitebbots
« Reply #62 on: 8 Apr 2018, 07:10 pm »
how about travel speakers that are stereo - separate L+R?
I guess possible to use a 3.5mm stereo to 3.5mm mono cable. many of these will be too large to carry 2 pieces.
