High powered SET amps for high efficiency Omegas?
0 Members and 1 Guest are viewing this topic. Read 4613 times.
Snoflo
Re: High powered SET amps for high efficiency Omegas?
« Reply #20 on: 9 Apr 2017, 06:24 pm »
I have an 845 SET amplifier running Super 3is full-range currently. For my small listening room (11x13'), an 845 SET is overkill power-wise for these speakers. Just crossing 1 watt on the power level meter on the amp is enough to deafen anybody. A 300B SET would be perfect, and I ran these speakers with a 2A3 SET just fine as well.
gregfisk
« Reply #21 on: 9 Apr 2017, 10:51 pm »
Hey Greg,
The finish is called Macassar Ebony.
Tim
Thank you very much, just an amazing looking system.
Whitestix
« Reply #22 on: 29 Apr 2017, 10:01 pm »
I am a new owner of the CAM's and will say that my Dennis Had EL84-based SET amp drives the hell out of the speakers, creating a warm liquid sound.  The DH amp costs around $1200 and is destined to be a classic.  It is a bargain and with upgraded tubes, it is well worth trying.
Whitestix
roscoe65
« Reply #23 on: 29 Apr 2017, 10:16 pm »
Whitestix - congratulations on the CAM's!
What is the configuration of your Inspire amp?  I know he did a number of EL84 SEP/SET amps in the past.
