NuPrime IDA-16
0 Members and 1 Guest are viewing this topic. Read 6730 times.
mresseguie
Re: NuPrime IDA-16
« Reply #20 on: 1 Apr 2017, 01:08 am »
Scott,
You're welcome.
I looked at B&W's website info on your speakers, and I reread your first post where you mentioned your room size. My inexpert opinion is to forget about the IDA-8. I think you are right to consider the IDA-16.
Sure, the IDA-8 has enough power to play music through your speakers. However, I'd like to argue that your speakers won't 'sing' if you know what I mean. You won't realize their full potential - and I'm not saying they won't get loud because they will. The highs may be a bit thin without that extra headroom and the midrange won't be quite as sweet as it should be.
It's been a while since I reviewed the IDA-16's specs, but I seem to recall both the preamp and DAC are superior to what you get in the IDA-8.
Enjoy your journey. I'm having a blast with my journey.
Michael (sometimes referred to as Mr. Esseguie  :lol: )
Samac
Re: NuPrime IDA-16
« Reply #21 on: 1 Apr 2017, 01:32 am »
Scott,
You're welcome.
Michael,
Thanks for the input. I know exactly what you mean. You nailed it; I want my speakers too sing. Like you said, just like the IDA-8 my 50 watt integrated can play very loud with my speakers but it doesn't sound very good.
I've got a tough decision to make with a tight budget but the input from you and Mark has been very helpful. Thanks again.
Scott
mresseguie
Re: NuPrime IDA-16
« Reply #22 on: 1 Apr 2017, 04:45 am »
Scott,
You've been sent a PM.
triumph
Re: NuPrime IDA-16
« Reply #23 on: 1 Apr 2017, 04:47 pm »
I'm sorry to say, but I think you are looking at the wrong end of your problem.
As it was stated, your 2 little 6.5" woofers per speaker will not be able to move much air in such a big room.  Might be one of the reason why you think it is thin sounding.
Changing to a new amp (hey, I'm all in when it comes to new toys, if they make sense), I doubt it will change much.
You have to work with the room you have, or adjust your expectations related to the products you can have.
Another reason for the sound being not so great is room interaction.  There is no perfect speaker that can be placed in any room and sound great.
If you can, physical room treatments should be installed.  That means bass traps, reflective panels, ...
If physical treatments are not possible, you could go DSP to adjust to your room's acoustics.
Just saying... There's no magic.  It's sound waves and math.  It's all a process of measuring and adapting to achieve the best sound we can have, with the means available to us.
Samac
Re: NuPrime IDA-16
« Reply #24 on: 1 Apr 2017, 05:09 pm »
Triumph,
Thanks for the feedback. Yeah, if I was disappointed with my speakers I would approach things differently. The thing is I am completely satisfied with them.
Low to medium volumes are good. It's that the 50 watts I have now has its limits with the rom size and load of the speakers. If I was in a room, say as big as 15'x20', I wouldn't even be looking fo an amp.
I need more brawn and headroom, thus the search for beefier watts.
Scott
Samac
Re: NuPrime IDA-16
« Reply #25 on: 3 Apr 2017, 12:10 am »
Mark and Michael,
I just ordered an IDA-16. Let's hope I have the same success that you've had with your NuPrimes. Thanks again for the helpful replies. I'll keep you posted.
Scott
Evoke
    • EVOKE Planar Loudspeakers
Re: NuPrime IDA-16
« Reply #26 on: 3 Apr 2017, 04:32 am »
Mark and Michael,
Scott
Congrats, Scott -
I'm sure the thread will enjoy hearing from you when you've had a chance to settle in from some critical listening.
Mark
mresseguie
Re: NuPrime IDA-16
« Reply #27 on: 3 Apr 2017, 07:52 am »
Scott,
I suspect you'll be quite happy with the IDA-16. Give it some time to properly break in. Then, come back here and give us your impressions.
Many people report that DACs (many different brands) required 100, 150, even 200 hours to fully break in. Mine need a minimum of 100 hours.
Enjoy!
John Casler
Re: NuPrime IDA-16
« Reply #28 on: 4 Apr 2017, 05:05 pm »
Hi Scott,
The larger number of IDA-8 reviews is simply due to the affordability and highly reviewed quality.  Audiophiles, when they move to higher level gear more often than not go to separates, rather than integrateds.
Regarding the IDA-16; It is easily the match of units costing many times more.  Michael mentioned enjoying his ST-10, and the amp section of the IDA-16 is most similar to the ST-10, except with MORE power.
It would be hard to think of any Integrated that would meet your needs as well at anywhere close to the price point.
As a dealer, I have spent considerable time with the IDA-16.  Most of it was through a pair of large floor standing speakers (VMPS RM-40) and in a 20 x 30 room.  The 200wpc ran those speakers like they were easy loads, so the power is there.
Your primary challenge is your listening position, and wishing to get a "near-field" experience with a "far-field" position.
As the sound leaves your speakers, it begins to disperse and reduce in energy.  That is, the sound energy spreads out and as it does loudness reduces.  As well reflected sound increases in a relationship to direct sound.
This then means you need to use a higher SPL to achieve clarity and detail.
The IDA-16 has not only significant power to allow this, but has the transparency and detail at higher volume levels to help you with your goals.
There are other methods and means too that would help, such as choosing a speaker with less directivity (dispersion) such as a Line Array, or some planar and ribbon type speakers with a reduced directivity.
In any event (keeping in mind I am a dealer) I think you will find the IDA-16 one of, if not your best choice, especially at that price point.  Many high quality DACs cost that much, and with the IDA-16, you get the whole package.
Samac
Re: NuPrime IDA-16
« Reply #29 on: 4 Apr 2017, 07:35 pm »
Hi Scott,
Hi, John,
Thanks for the reply. Thanks for sharing your experience with the IDA-16. Yes, in my far-field situation things are different; And what you mentioned is what I'm looking for. Along with the extra transparency and detail I want an ease to the music and not have to worry about taxing the amp or damaging my speakers.
The helpful replies from you, Michael and Mark have been reassuring that after all my "research" I may have made a very good decision (and believe me I have spent well over a year reading about and listening to lots of gear :o).
Oh, man, the near-field experience. I remember those days well. I once had a seven foot equilateral set up. Wow, I had a recording like Roger Waters "Amused to Death" placing pianos 30' to my right in the next room with dogs and voices all over the place.:thumb:
Alas, those days are over. Now I just need the power to "jam" to the music and "crank it" when we watch "Captain America" as a family :D
Again, thanks for the reply and the encouragement.
Scott
Samac
Re: NuPrime IDA-16
« Reply #30 on: 6 Apr 2017, 01:59 pm »
FedEx tells me it's due to arrive Tuesday. The wait begins. Really looking forward to this. :thumb:
Scott
mresseguie
Re: NuPrime IDA-16
« Reply #31 on: 6 Apr 2017, 02:53 pm »
Take your mind off it or the anticipation will drive you (and likely your wife) mad.
Okay. I admit to not taking my own advice when I ordered various pieces of equipment. I am looking forward to your impressions - especially once it's got >100 hours on it.  :thumb:
Michael
Evoke
Re: NuPrime IDA-16
« Reply #32 on: 6 Apr 2017, 03:55 pm »
Scott
When I got my new car I scrubbed the garage floor and sat there for a while. I'm not normal however  :lol:
Samac
Re: NuPrime IDA-16
« Reply #33 on: 6 Apr 2017, 03:59 pm »
Michael
I will do my best, Michael. :wink: I think I've kept my cool pretty well so far. My wife's good about it . Every once in awhile I'll have to talk about audio (you know, just to get it out of my system). She'll patiently listen and when I notice her eyes glaze over I stop. :green: It's a good balance.
You know who I drive nuts; my girls. I'll do something occasionally like a cable and I'll ask them if they notice anything. They've come to the point where they say, "No, I never notice anything.". Although when I got my B&W speakers my fifteen year old said, "I gotta say, those a pretty cool.".
I'll make a brief first impression post after it has a couple hours. Then I'll settle in with it and post more thoughts.
Scott
Samac
Re: NuPrime IDA-16
« Reply #34 on: 6 Apr 2017, 04:04 pm »
Mark,
I can completely relate and I think you are normal. I mean, who wouldn't do that? :thumb:
Hey, when I put the amp in I'll dust and mop the floor. The system always sound better after the room has been cleaned. :D
Scott
John Casler
Re: NuPrime IDA-16
« Reply #35 on: 6 Apr 2017, 04:20 pm »
Listen to your favorite "reference" cuts and be prepared to hear more and deeper into the recording.  In some cases it may be significant, and in others subtle.
Bass, fullness, transparency, and detail should be greater.
Do, be prepared to have some of your less well engineered cuts be maybe less fullfilling if they were not recorded or engineered well.
However, on well done recordings, your Sonic Enjoyment will be enhanced.
Listen for Bass Harmonics, and detail and transparency without edgy harshness.
Have fun. . . :thumb:
Samac
Re: NuPrime IDA-16
« Reply #36 on: 6 Apr 2017, 04:52 pm »
Thanks, John. Will do.
I actually do have less well engineered recordings in my reference songs that I use when I audition gear. I find  that the more transparent, neutral gear will let you know that it's a bad recording but doesnt highlight or make it worse than it is. From what I've read it sounds like the IDA-16 is a transparent, neutral, balanced piece of gear.
"Bass, fullness, transparency and detail should be greater"
Very excited to hear that.
I look forward to hearing what the IDA-16 will do with my favorite music. You mention bass harmonics; man, I'm a bass freak in that regard. I CANNOT wait to hear how the IDA-16 does bass. :thumb:
Scott
Samac
Re: NuPrime IDA-16
« Reply #37 on: 10 Apr 2017, 02:52 pm »
It's on the truck and out for delivery (a surprise because it's a day early, woo hoo!). I have to laugh at myself because I have a mix of nervous apprehension and excitement. This is a big change and I have high hopes.
Anyway, thought I'd post this. I always enjoy posts from members excited about their recent acquisitions. :D
Scott
damguz
Re: NuPrime IDA-16
« Reply #38 on: 13 Apr 2017, 11:07 am »
Come on.  I have been following your thread and anguish over the performance of the new Toy. 3 days have passed since arrival, and?
mresseguie
Re: NuPrime IDA-16
« Reply #39 on: 13 Apr 2017, 12:08 pm »
C'mon, Scott.
My life is on hold, too! Okay. Maybe not on hold, but I am curious.
