Square motor grounding?
0 Members and 1 Guest are viewing this topic. Read 1371 times.
Vic
« on: 23 Mar 2017, 09:46 pm »
I'd like to address the slight hum I get from my two prong ungrounded motor.
Has anybody successfully upgraded the power cord to a their prong grounded cord? If so what did you attach the ground wire to?
If you're and owner of the later grounded square motor can you describe or photograph the ground wire connection?
Thanks Vic
