0 Members and 1 Guest are viewing this topic. Read 19751 times.
Hmm, so is this why planar drivers sound so much cleaner and more detailed than cone drivers? Not because the material is "lighter and thinner", but because there's magnets at the front and back of the driver so it's physically started and stopped more quickly/precisely?
people need to stop believing in this stuff, i also did years ago. the absolute worst speaker is one consisting of a fullrange driver, polarresponse will be terrible and distortion goes thru the roof. + phase issues and...well virtually all problems you can get in a speaker = obvious coloration.its not really an oppinion, its a scientific fact. would you use tweeters as woofers? no, you shouldnt use woofers as tweeters either. long wavelenghts = large cones and some excurtion, small wavelenghts = tweeters.a crossover does not color the sound when its done correctly
I have never attempted a definition of settling time, but here goes: "the time taken by the driver or the system (driver and box or panel) to stop generating acoustic output once the input signal stops". In an ideal transducer, whether microphone or loudspeaker, settling time and its inverse—rise time—would be instantaneous. In an imperfect world we have to be satisfied with 'quick'. It could be measured in terms like room reverb time—R60—where the time for the reverberation in the room to drop to 60dB below the triggering impulse is measured in fractions of a second.Years ago I cleverly (not!) named my speakers "Quiet Speakers" in deference to this target characteristic. The idea that a good speaker would be quiet—ideally silent—in terms of producing no sound of its own in the process of converting the input electrical signal to acoustic output.In Europe they sometimes include a revealing multitone-graph which displays the amount of noise generated by the speaker (intermodulation distortion) quite clearly, when fed by multiple discrete tones. Here's an example from this page (click on 'Intermodulation Distortion'):http://www.neumann-kh-line.com/neumann-kh/home_en.nsf/root/prof-monitoring_knowledge_glossary_measurementI think this is a revealing measurement and should be as important as a waterfall plot in aiding visualization of a speaker's distortion characteristic. I'd like to see this included in Stereophile's measurements, for example.
Sorry Russell, but you're all over the place there, no clear definition at all. For any of it to relate to audibility, a clear definition of what is being tested is needed...and controlled listening tests with "other" factors accounted for and things like perceptual masking etc. in play. Especially when listening to music, vs tone and even multitone test signals.cheers,AJ
I think the issue of bass quality and variability is a huge one—perhaps the biggest untamed region in the whole issue of the processing and reproduction of recorded sound. I also think a large part of that is due to the way bass response is measured, particularly not taking into account the settling time of the system in response to signals at various frequencies through the range. In other words, two speakers that measured identically flat right through the range of, say, 200 Hz on down when fed by a slow sweep might sound very different through that same range when fed a music signal
I don't understand what your point of confusion or contention is. To me it's pretty straightforward: transducers don't 'shut up' after having produced a sound and that adds mud to the signal. The slow the settling time, or post-ringing, if you prefer, the more mud.
Actually, the settling behavior of planars tends to be really messy and random, but at least it also tends to be very quick and low in level. What helps planars is the excellent coupling of the diaphragm to the air, such that the air itself puts a brake on large scale overhang. It's a function of the diaphragm mass to the mass of the air to which it is coupled; vastly better in planars (especially electrostatics compared to planar magnetics which have more mass per square inch of radiating surface) than cones of any type. Certain materials in cones and domes are also superior due to their inherent self-damping characteristics, coupled with lightness and tensile strength, such as magnesium and alloys of magnesium which can make wonderful midrange cones and beryllium. http://www.6moons.com/audioreviews2/fostex3/2.htmlHere, the advantage of magnesium over aluminum is demonstrated by dropping two cones, one of each metal, onto a hard surface. Fostex makes the same speaker with cones and domes in both materials, with the magnesium version being roughly $1000 more expensive.https://youtu.be/wrdYofPYD4M?t=77Incidentally, Joachim Gerhard of Audio Physic has been observed using the same technique to choose likely cone materials!There are three graphs comparing the settling time, or post ringing as it is called here, of aluminum, titanium and magnesium halfway down this page: http://www.6moons.com/audioreviews2/fostex/1.html
I cant imagine what FR driver you listened, maybe a hi power raw pro FR and dislike the sound. With 1 FR driver per channel you get 1 point source for all the freq, you will have zero probs in polar response and phase, even in pro audio coaxial drivers you dont have probs in polar response and phase.If the FR is a low power hifi model it have power handling about 30W, when it is over powered you will listen it and should turn down the volume or it will blow, even in this case you wont get coloration. I unknow how afew grams paper cone may add coloration.Among the various probs xovers introduce in the music what bother me is the lack of the rich musical harmonics after the signal pass an xover, the result is poor image of the musical instruments and an sound stage flat.To know what the soundstage Iam talking about please listen a Carver Amazing(with no toe-in) and plenty space around, it have tone controls but no xover, or a quality FR direct from the amp as Fostex, Alpair, Omega or even Dayton.Even 50 years old FRs are better than tweeters and woofers>http://glowinthedarkaudio.com/zenith-49cz852.html
I agree, FR is what I have preferred for the last 50' years. Crossovers is like a speed bump, they can be enjoyable to listen to, but for quickness and detail, FR's are the best.
Thanks Tom, I would like xovers dont prejudice the musical signal but it dont happens, even the huge 3D soundstage from the Carver Amazing are not detailed as a FR.
There is a great deal of magic or musical luck? when you pair a decent full range driver on an open baffle.
While I agree that measurement is a useful tool, ultimately what sounds good to a person who builds their own speakers (ie for themselves) may not find it necessary. I used Visaton b200 on OB for a long time. I ran them full range on their own for about 2 years. I later added a set of biamped 12 inch OB subs and liked that more.
I am currently considering a full range plus woofer setup again.
Just have anyone who claims this to post a full set of measurements, not just anecdotal subjective opinions.Will quickly see why filters and multi-way are a very good idea.
I have been following that logic for over 35 years. I finally found that to please my ears, I had to break all of the specification/measurement rules. As a music lover (not a specification lover) I frankly don't care how it measures. Do you put yourself on an EKG and blood pressure monitor when you are watching a movie or eating at a good restaurant to verify that the content/stimuli is a positive experience for you?
Have to agree that most single drivers are most appropriately referred to as wide range drivers. And multi way can be satisfying.
If you limit frequency response, be it upper or lower frequencies, of a wideband driver with a crossover(s), what are you gaining?
