Best XLR connector
0 Members and 1 Guest are viewing this topic. Read 1045 times.
bebop86
Best XLR connector
« on: 22 Mar 2017, 01:45 am »
Was looking at the Furutech CF-601 M and 602f xlr connectors- do you have a recommendation on which xlr connector would be a good choice- using an all tube system- thanks
Jeff
  • Test...
    • Sonic Craft, Inc.
maxima95
Re: Best XLR connector
« Reply #2 on: 22 Mar 2017, 06:29 pm »
The best we have: http://www.soniccraft.com/product_info.php/neotech-nex-occ-rh-xlr-p-2023
Highly recommended: http://www.soniccraft.com/product_info.php/neotech-nc-06613g-xlr-p-2106
Best bang for the buck: http://www.soniccraft.com/product_info.php/xhadow-reference-xlrm-p-1557
All of the above are superior to the Furutech IMO.
For 4 items:
The best costs $262.50
Highly recommended costs $225.00
Best bang for the buck costs $252.00.
Is there something less than $200 for 4 pieces that is good for the money?
bebop86
« Reply #3 on: 22 Mar 2017, 06:34 pm »
Jeff thanks- curious as to why you like the Neotech over the Furutech- I have no preference but always heard good things about the Furutech although if the Neotech is as good I do not mind saving some $$$$$$$$$$$-thks
Jeff
  • Test...
    • Sonic Craft, Inc.
« Reply #4 on: 22 Mar 2017, 07:08 pm »
For 4 items:
Given the OPs query, my reply was appropriate, and accurate.  If you are looking for good value below that, you are looking at brass (and maybe bronze) allows.  In that category, a nice brass with direct Gold (pure) plate.  That would land us here: http://www.soniccraft.com/product_info.php/vampire-xlrf-p-1556 provided $8.39 per connector is in the budget.
Jeff
  • Test...
    • Sonic Craft, Inc.
« Reply #5 on: 22 Mar 2017, 07:19 pm »
The Furutech's reputation is good for a couple of reasons.  The company make considerable effort to achieve a good reputation.  The parts have good fit and finish.  They sound good.  The part I listed sound better.  This is likely due to the choice of pure Copper and Silver conductors vs Copper alloys and Phosphor Bronze.
