For Sale: Amplification
SOLD: Class D Audio SDA 254 Amp
0 Members and 1 Guest are viewing this topic. Read 2211 times.
walkern
10 Mar 2017, 07:32 pm »
I'm the original owner of this Class D Audio SDS 254 (125 wpc into 8 ohms). It is built using an SMPS power supply rather than the analog supply commonly sold by Class D Audio. The unit is housed in a very homely aluminum chassis. I inserted fixed Vishay naked foil resistors on inputs rather than using the supplied pots as I found this sounded significantly better. Otherwise, the unit is stock / original, and the pots supplied by Class D are included. Simple push button on-off switch on the front, and a female IEC AC inlet on the back along with the RCA inputs and speaker terminal outputs. Works great and sounds quite good. Note that there is no on-off led to indicate the status of the amp as you can see through the vent holes in the top of the chassis and spot the yellow or blue on-off leds built into the board. The unit sounds better if it has been plugged in for a while (seems to need to warm up, and is doing so even when switched off), and it runs warm (contrary to what I expected) when in use. No original box, but will be carefully packed and shipped. Asking $190 plus actual cost of shipping in CONUS.
Last Edit: 9 May 2017, 06:41 pm by walkern
The elephant normally IS the room
Re: FS: Class D Audio SDA 254 Amp
11 Mar 2017, 11:41 am »
Nice.
Where is it shipping out from?
walkern
Reply #2 on:
11 Mar 2017, 03:10 pm »
I'm in the Los Angeles area.
walkern
Reply #3 on:
19 Mar 2017, 02:17 pm »
Bump with lowered price.
walkern
Reply #4 on:
7 Apr 2017, 03:44 pm »
Bump with price lowered again.
walkern
Reply #5 on:
5 May 2017, 03:10 pm »
Bump for one last price reduction
rooster2001
Reply #6 on:
9 May 2017, 06:40 pm »
Hello - Shipping quote to 29576? Thanks,
Eddie
walkern
Re: SOLD: Class D Audio SDA 254 Amp
Reply #7 on:
9 May 2017, 06:41 pm »
Sorry Eddie but the amp sold last evening and went out this morning.
rooster2001
Reply #8 on:
9 May 2017, 06:46 pm »
Congrats on the sale. My fault for not contacting sooner.
