0 Members and 1 Guest are viewing this topic. Read 3860 times.
You're mixing your mashed potatoes with your peas. Note there's no such thing as a digital amp. That's a misnomer. Class D doesn't stand for "digital." https://en.m.wikipedia.org/wiki/Amplifier
Chord Electronics is said to be working on a line of amps in this "class," which takes the digital signal, and without adding distortion amplifies the sound. They say the first one will be 20 WPC. So, I'm wondering if this is a whole deal, or has it been done before.Google pulls up nothing but Class D, but I guarantee a switching amp is not what they are talking about.
yes it has been done
Like what?
The recently released Exogal Ion is going in that direction, although not a class A amp. They sell it as a power dac, and not just a power amp.http://www.exogal.com/index.php/products/ion-power-dac
The Comet/Ion combo never converts digital to analog, so there is no D/A process, PCM to PWM directly driving the outputs, simply a power supply that drives speakers.
Some other examples of the digital amp the OP may be referring to are the TacT 2150, which is what I use with my DEQX HD-4 sending it a digital signal. The NAD M2 is another example and I think NAD has used this in other amps in their line as well (but not all). But the M2 and the TacT 2150 are not Class A. Not entirely sure if the traditional amp typologies (Class A vs Class A/B) apply to this type of digital amp. But they put out a lot more power than you'd expect from a Class A design (or rather a Class A design that isn't massively heatsinked etc like the Pass big boys).
I misspoke about PCM to PWM, apparently Exogal doesn't use PWM to drive their outputs, they won't actually disclose the method they use, too much time & effort in R&D to give away, anyway the Comet/Ion power DAC sounds spectacular.
