0 Members and 1 Guest are viewing this topic. Read 10748 times.
My iPurifier just arrived DOA from Amazon. Unfortunately, it will not lock to the source signal. Red light stays on all the time. I verified signal is on, and music plays from the DAC when I take the iPurifier out and connect the spdif cable direct to the source.I tried 2 sources, Sonos ZP-80 and an old Oppo CDP.Any suggestions to make it work? I have a G2G tomorrow, wanted to share it with the guys. ThanksRichEDIT: Right after I posted, I saw the picture on the above post, saw iPurifier was connected to the DAC input. I was using it connected to the source output. When I moved it to the input of my DAC the blue light came on and music is playing, for both the Sonos and Oppo. Is that normal behavior? I didn't see mention of that in the instructions, but I didn't read them too carefully. Thanks
I never experienced that as an issue. It could be the Spdif IPurifier or how your Dac actually sounds? 200 hours seems to be the target break in and try rotating the iPower in the outlet, some have noticed a difference by doing this. Chris
How much of a break in do these need?I have had one since early September. There is a bit of bass resonance and it makes my gear sound a little boomy and thick on some bass recordings. Occasionally, it gets bad enough that my ears ring after prolonged listening.Does this go away?Thanks
By rotating the iPower do you mean reversing the polarity of the +, - prongs ie. how they are plugged into the AC outlet? Unfortunately, given the size of the iPower, there is only one way I can plug it into my distributor. Reorienting it another way, blocks the other outlets from being used. I did recall asking iFi about the polarity of the prongs but they said it didn't matter.Also, I don't presume the way I have plugged in the IPurifier to the DAC input matters? Again, on my DAC, it is very close to the USB input which I have a ISO Regen on. So I ended up only being able to fit it with the larger red light on the upside ie. the iFi logo is facing downwards.Thanks
Bottom line, I cannot find a real scenario where ifi iPurifier does any good. Yet it was easy to show that it does some harm. NOT RECOMMENDED.Save your money for music, or a better DAC driven by isolated asynchronous USB signal.
