0 Members and 1 Guest are viewing this topic. Read 3844 times.
Interesting--so you're planning to unmount the panel and splice in the miniDSP downstream of the crossover and signal processing before the Class H LF amp?https://www.qsc.com/resource-files/productresources/spk/discontinued/hpr/q_spk_hpr_series_specs.pdfWhat are you using as a source?
what you need is room treatment,most peaks and dips have nothing to do with dsp treatment,there will still be there at a lesser intensity.MHO.
I think you are on the right track however I would put the DSP in front of the amp in the low level imput. It makes improvements everywhere I'd used in moderation. I use a Lyngdorf TDAI 2170 integrated amp with room perfect DSP and I will never go back. I have played with room treatments too. They are a tool (and a good one) but will not cure all the things a good DSP can fix.
DSP (or EQ) should be the last step in obtaining proper frequency balance, after having the right speakers, the right room, the right setup, and necessary treatments. DSP/EQ can only be setup for a single listening location, so can be doing some weird things overall. Yes, narrow dips can't be heard thankfully because if really deep (say 30 dB) the DSP/EQ would call for sucking 1,000 times the power in order to compensate, so use with care.Most audiophiles lust for too much gear and so have speakers that are obviously too much for the given room. This undoubtedly is your case as the QSC HPR-153i are intended for professional sound reinforcement applications, not home use. They are rated 41-17,500 Hz +/- 3 dB, 134 dB at 1 meter maximum output. At sane in-room sound pressure levels you'd be using 0.01 watts per amp, which is well out of the sweet range of a solid state amp. This is a sledge hammer for more of a finish carpentry job. Can you say "way overkill"? I'd honestly dump the speakers and start over.Last summer I bought Dynaudio BM5 Mk III, also active, but "just" 2-way monitors. They are rated 42 - 24,000 Hz, 118 dB at 1 meter maximum output and have roll offs for use with subwoofers - frankly a much more reasonable solution for home use. I am fortunate to have the right room (ala Cardas), the right setup (near-field - close to Cardas), treatments (although not really needed in my room/setup), and DSP (only to replace baffle step circuits that I removed from my main speakers).
Yeah, of course that would be ideal. I just can't with my current setup. I know its possible to minimize the peaks and dips via DSP. I was doing it with Audiolense for a while (on a full-range basis).-Jim
There is no reason to think that a speaker is "overkill" for a given room (cost/aesthetics aside) unless you are a. allergic to EQ or b. you are physically constrained to be at a distance from the speaker where lobing issues come into play (i.e. nearfield/farfield/"driver integration").In the end, it's all just geometry
Hey Guys So, I have QSC HPR-153i active 3-way towers....
I've consiered doing something similar with my Salk 3-ways. I used to run EQ'd subs driven by Behringer pro audio amps for my 2-channel system. Now with the 3-ways, I don't run subs. The Salks are bi-wireable, so I was going to drive the mids and tweeters with my monoblocks, and add a 3000DSP to drive the 10" bass drivers while EQ'ing them from ~20-400Hz. Now I'm thinking I'd just add a MiniDSP in front of the monoblocks, and use them for the 10" drivers. I'd then get a smaller 2-channel amp to drive the mids and tweeters.At the end of the day, my bass isn't perfect frequency response wise, but it sounds close. I only have a larger peak at 36Hz. Other than that, my room measures amazingly good. Not to much music really excites my bass peak to worry too much. Still, I'm an audiophile at heart...
Paint or dye mate black all inside the speaker enclosure, it will reduce some treble.
Have you tried this and found it to work?
