How to get rid of chrome shine/ temporarily
0 Members and 1 Guest are viewing this topic. Read 1924 times.
stlrman
« on: 24 Feb 2017, 07:07 pm »
So I want to scan or photograph a motorcycle to create a 3d image.
Chrome / shiny surfaces are the worst for this .
Is there any type of black spray or powder, that can very easily be washed away with a hose, that won't damage the chrome.
Safe enough that someone would let me spray their prized Harley .
 Does such a product exist ?
Armaegis
Re: How to get rid of chrome shine/ temporarily
« Reply #1 on: 24 Feb 2017, 07:17 pm »
The simplest/cheapest would be to use a spray bottle to mist with water and shake a vacuum bag or furnace filter at it.
stlrman
« Reply #3 on: 24 Feb 2017, 08:50 pm »
Thanks gentleman!! :thumb:
Big Red Machine
« Reply #4 on: 24 Feb 2017, 11:14 pm »
Wax on without the wax off.
Armaegis
« Reply #5 on: 24 Feb 2017, 11:24 pm »
Quite labour intensive though...
Bob2
« Reply #6 on: 25 Feb 2017, 01:06 am »
"would let me spray their prized Harley "
I suggest you tread lightly there. Most of the guys I know would probably offer to break off a body part and stick it in an uncomfortable place..
I would say that you might want to talk to a dealer. Ask him if he knows if any of their customers might be interested..
Just want to see you stay in one piece there Stlrman. Hate to loose a perfectly good audiophile!
stlrman
« Reply #7 on: 25 Feb 2017, 02:43 am »
I hear you Bob!!
Probably gonna skip the entire idea BUT check this out:
This is a 3d Harley render, what I had envisioned.
https://sketchfab.com/models/79dc00298bf449d7bcfdf6eb32bd15ac
But it took this guy 5 days to render this !! Waaay too much work flow for me .
drphoto
« Reply #8 on: 25 Feb 2017, 04:01 am »
Easy peazy. There is a product called "dulling spray" made by Krylon. Comes in a spray can. You can pick up in any good pro camera store or order from someplace like B&H. spray on light coats. Wipe off with soft cloth. It's essentially a wax dispersed in a solvent. (Don't get "Matte Spray"....that's an acrylic product.) It works well but sometimes in close ups you can see a somewhat mottled appearance. If the dulling spray doesn't come off cleanly then a non polar solvent like mineral spirits would work, but generally don't need. Besides easy to remove, it will not harm paint or chrome in any way.
« Last Edit: 25 Feb 2017, 05:25 am by drphoto »
SteveFord
« Reply #9 on: 25 Feb 2017, 11:35 am »
Just let me ride it to work for a few days.
There won't by anything shiny left on it by mid week!
stlrman
« Reply #10 on: 25 Feb 2017, 03:40 pm »
Thanks very much DrPhoto!!
Steve, Pittsburgh's air used to turn everything grey.
SteveFord
« Reply #11 on: 25 Feb 2017, 05:50 pm »
Pittsburgh must be downwind from Harrisburg.
Sounds like you were lucky enough to escape.
drphoto
« Reply #12 on: 25 Feb 2017, 06:51 pm »
Hey Todd, I didn't see Dulling Spray on B&H, which is hard to believe. Set Shop carries but won't ship spray cans. Hopefully Pittsburgh still has a B&M photo store that might have. An art supply store MAY have it.
I'll send you a partial can if you can't find it.
This stuff is exactly what you asked about.
