PEQ•1 MKII Phono Preamplifier Now Shipping !!!
0 Members and 1 Guest are viewing this topic. Read 3612 times.
CIAudio
« on: 14 Feb 2017, 10:03 pm »
Our new PEQ•1 MKII Dual Mono MM/MC Phono Preamplifier is finally shipping... and well worth the wait!
These are not yet on our website but are available via phone order.
We hope to have the website updated by the end of the week.
Channel Islands Audio
(805) 984-8282
« Last Edit: 16 Feb 2017, 04:06 am by CIAudio »
CIAudio
Re: PEQ•1 MKII Phono Preamplifier Now Shipping !!!
« Reply #1 on: 15 Feb 2017, 04:24 pm »
and PLC•1 MKII now has matching cosmetics  :D
abuhannibal
« Reply #2 on: 15 Feb 2017, 04:37 pm »
Can you post specs (gain and impedance options) and price on the PEQ-1?
CIAudio
« Reply #3 on: 15 Feb 2017, 04:48 pm »
Performance Specifications
   RIAA Accuracy:                  +/- 0.2 dB
   THD + Noise:                      < .002% (1kHz Unweighted/45dB gain/10mV)
   IMD:                                   < .002% (SMPTE)
   Crosstalk:                           > 108dB
   Cartridge Loading:
           Resistance:                    47KΩ • 10KΩ • 1Ω • 100Ω
           Capacitance:                  100pf • 270pf • 370pf
   Gain:                                   45dB • 60dB
   Subsonic Filter:                   -3dB @ 18Hz
   Output Impedance:            100 ohms
   Operating Voltage:              120V AC Input • 14V AC Output (Standard Supply)
   Power Consumption:          < 4.0 Watts
   Dimensions:                       8.50"W x 2.75"H x 6.50"D
   Weight:                               8.0 lbs. (actual), 9.0 lbs. (shipping)
Price  $995
5 Year Warranty/Free shipping in the continental US
Custom gain and cartridge loading options are available for a nominal fee
« Last Edit: 18 Feb 2017, 06:21 pm by CIAudio »
CIAudio
« Reply #4 on: 16 Feb 2017, 09:27 pm »
We also do packages with Clearaudio Turntables, Dynavector cartridges, etc.
Call us for details...
CIAudio (805) 984-8282
CIAudio
« Reply #5 on: 17 Feb 2017, 10:07 pm »
We are finishing up the matching AC•15 MKII Upgrade Power Supply for our PEQ•MKII Phono Preamp.
It uses a 35VA encapsulated toroid transformer, has AC line filtering, 120~240V input selection, dual 15VAC outputs with dual common-mode choke output filtering. Looks are the same as VDC but no LED and uses a 7 pin DIN connector for output. Hope to ship around May 1st.
Cost will be $299
CIAudio
Rocket
« Reply #7 on: 25 Feb 2017, 10:40 am »
Hi Dusty,
Congratulations on the new phono stage.  Glad to see it can take 240 voltage for overseas customers.
Cheers Rod
CIAudio
« Reply #8 on: 4 Mar 2017, 03:29 am »
Hi Dusty,
Cheers Rod
The supplied AC adapter is 120V only, but adding the AC•15 MKII improves perfomance and allows for 220~240V mains.
The custom transformer has dedicated output windings for L & R channels to take advantage of the dual-mono circuit design.
Production transformers and circuit boards should arrive next week. I just finished the front/rear panel designs & artwork... probably 4-6 weeks from shipping production units.
CIAudio
« Reply #9 on: 7 Mar 2017, 12:35 am »
The PEQ•1 MKII Phono Preamplifier can now be ordered from the website.
http://ciaudio.com/products/PEQ1
We're working on an all new site to launch next month.
The new site will have more information and many new features.. stay tuned!
