0 Members and 1 Guest are viewing this topic. Read 20094 times.
Thanks Roscoe. VTV, miss those guys.
That would have to be tested in an identical circuit. There are transformer shootouts from time to time (the most recent I've seen is a budget transformer shootout over at JELabs between Edcor and Noguchi transformers) but not as frequently as there were about 20 years ago or so, when SET's were mostly DIYor custom. The problem is that a real shootout of all or most available transformers would require us to have $5,000 of iron available to swap into a circuit.Given a reputable hand winder and the materials and tech that are accepted to perform well, it becomes a matter of choice. Your Electraprint iron is of good reputation but does fall into the lower (but not lowest) price range. One advantage of EP iron is like many US manufacturers you can specify exactly the iron you would like within the confines of their factory capabilities. The partial silver secondaries seem to be a particular bargain.20 years ago we could choose from the big Japanese names (Tango, Tamura, etc.), Audio Note, Bartilucci, Magnequest, Lundahl, Electraprint, and some custom options available from Cary (Audio Electronics Supply - probably Edcor), Edcor and a handful of others. Today, Tango is gone (RIP 2013), AES no longer exists, but we have access to a large Chinese manufacturing sector (for better or worse) and newer players have come on the scene, such as James (Taiwan) and the renewed availability of Hashimoto/Sansui (Japan). We can pick almost any price point and specification from $50 to $750 for the typical 2A3/300B transformer.Personally I like Hashimoto, but Shindo uses Lundahl and others like Wavelength use Magnequest. Decware uses Edcor (I think) and Fi has switched from Magnequest to Hashimoto.But to speak more directly to your question, this test hints at the relative quality of Electraprint: http://www.meta-gizmo.org/Tri/vtv-se.html
FullRangeDude ! currently using Raven's from Birch Acoustic. lovely speakers. Vapor meets Omega.To me , the 45 is holographic + resolved with a touch of romance YMMVDwight
Happyrabbit,I can't agree more with your description of the 45.I am listening now to my recent built 45-76 amp. Used James transformer that I find a very good compromise price quality.I am using a 01A preamp to get a little gain needed for a 3Vrms input sensitivity amp.I am enjoying so much this combination. My speakers are Alpair 12P by Mark Audio.Cheers,Radu
