0 Members and 1 Guest are viewing this topic. Read 6106 times.
Why not remove the spade connectors and connect the bare wire to the mounting strips.
I went with 2 pair (shotgun bi-wire) of the AudioQuest CV-8 cables. Music Direct has them starting at $350 per-pair. Sell the Cardas.
Thanks for the suggestion. I may try this. I assume the AQ spades fit inside the barriers ok? Is it kind of crowded behind the speaker where those two cables and four connectors all come together around the barrier strip?
I'm a bit dubious on the asymmetrical wire dielectric strategy of the new AQ line (when using a fully-balanced source), but to be fair, I haven't heard any of the new line.
