Super 3-1.5 High Output on the truck
0 Members and 1 Guest are viewing this topic. Read 16372 times.
sabocat
« on: 27 Jan 2017, 12:58 pm »
I placed an order with Louis recently for a pair of the dual driver 3-1.5 bookshelf speakers, and they are due to arrive on monday! I've assembled what I think will be an ideal bedroom set-up: a JWN 6V6 amp putting out around 15 wpc; Conrad Johnson PV-15;  Lounge Audio Copla; Thorens TD-125MKII with a Denon 301 MKII cart; Neko Audio DAC hooked up to a mac mini. The amp also has a headphone jack, so I've been dialing it in and have it just about ready for the speakers. Will follow with photos next week!
BTW, Louis has been a pleasure to communicate with via email. He answered all my questions patiently and steered me in the right direction.
« Last Edit: 28 Jan 2017, 09:32 am by sabocat »
sonicxtc
Re: Super 3i High Output on the truck
« Reply #1 on: 27 Jan 2017, 03:26 pm »
Congratulations. I look forward to your impressions.
BTW, what makes these "high output?"
What is the rated efficiency and frequency response?
sabocat
Re: Super 3-1.5 High Output on the truck
« Reply #2 on: 27 Jan 2017, 03:56 pm »
They have two drivers instead of just one. Not sure about the specs.
« Last Edit: 28 Jan 2017, 09:42 am by sabocat »
Canada Rob
« Reply #3 on: 27 Jan 2017, 06:23 pm »
They are not the Super 3i which is and always will be single driver per cabinet.  They are the new Super 3-1.5 High Output Monitor and they are bigger than a Super 3U.  Louis hopes to get some pictures up on the AC soon.  They are the monitor version of the speaker Steve has.
It's these: http://www.audiocircle.com/index.php?topic=147959.0
roscoe65
« Reply #4 on: 27 Jan 2017, 07:41 pm »
Have these changed since Louis posted the "final version"  http://www.audiocircle.com/index.php?topic=146160.0?
He described these as 16" x 8" x 12.5" = 1,600 cu in (gross).  My Super 3U's are 15" x 9" x 12.5" - 1,687.5 cu in (gross).
sabocat
« Reply #5 on: 27 Jan 2017, 08:12 pm »
Thank you for clarifying that for the readers. Apologies for the confusion. I changed the header.
« Last Edit: 28 Jan 2017, 09:41 am by sabocat »
OzarkTom
« Reply #6 on: 27 Jan 2017, 08:14 pm »
How many $ is that version?
sabocat
« Reply #7 on: 27 Jan 2017, 08:42 pm »
$1300 and some change.
« Reply #8 on: 27 Jan 2017, 10:25 pm »
which finish did you get?
OzarkTom
« Reply #9 on: 28 Jan 2017, 01:38 am »
That settles my decision, since it saves me 1k.. These with a Fleawatt and ITube 2 would make a heck of a 2k system and should satisfy the most picky audiophile very easily.
Spend a little more and get a UFO amp from Decware or the Wolf Ear Kitoki amp.
Canada Rob
« Reply #10 on: 28 Jan 2017, 01:39 am »
To my knowledge they haven't changed since that posting.
roscoe65
« Reply #11 on: 28 Jan 2017, 03:07 am »
I would argue that these with a used Decware Zen would make a great $2k system.
sabocat
« Reply #12 on: 28 Jan 2017, 09:30 am »
If I recall correctly, I got the cheaper finish in walnut.
sabocat
« Reply #13 on: 28 Jan 2017, 12:35 pm »
Here are some pics:
roscoe65
« Reply #14 on: 28 Jan 2017, 12:58 pm »
Wow!  Those speakers really disappear in the room.
sabocat
« Reply #15 on: 28 Jan 2017, 01:14 pm »
Haha. The really good news is the speakers are already on the delivery truck today. So if you hold on a bit they may make a fairly quick appearance!
roscoe65
« Reply #16 on: 28 Jan 2017, 02:02 pm »
Those console amps can be real sleepers, especially those from Pilot and surprisingly Magnavox.  You used to be able to get the Magnavox amps for almost nothing but work got out.  IIRC when Dennis Had started his "retirement" business he started modding Magnavox SE EL84 amps and reselling them.  THat sort of evolved into his current SE amps.  You can still get them pretty cheap (less than $300 restored or unrestored) but some people are trying to sell them for over $1,000.
sabocat
« Reply #17 on: 28 Jan 2017, 02:29 pm »
Jim Nicholls modified this amp for me some time ago, installing his own circuit, based on the work of Lance Cochrane. Lance in turn uses a modified circuit based on some of the circuits found in these older console amps. They use a grounded-cathode input gain stage followed by a floating paraphase phase splitter, according to Dick Olsher. All I know is it sounds really good with the headphones.
rico11764
« Reply #18 on: 29 Jan 2017, 10:39 pm »
A little off topic, but how do you like the Neko Audio Dac?
sabocat
« Reply #19 on: 30 Jan 2017, 06:18 pm »
OK here we go. so far so good. time for the extended break-in!
I really like the Neko DAC. I have the MKII.
