Help needed on Roon/HQP/Lampi Superkomputer/GG
0 Members and 1 Guest are viewing this topic. Read 2020 times.
PhilipAC
« on: 7 Jan 2017, 04:13 pm »
Hi
I am setting up the above server and HQP will not let me copy DSD256 files to the database. I realise that my GG will downsample them at present to DSD128 but I would at least like to load the files.
Any ideas please?
Philip
PhilipAC
Re: Help needed on Roon/HQP/Lampi Superkomputer/GG
« Reply #1 on: 7 Jan 2017, 04:20 pm »
Sorry. Correction. It is not the DSD256 that is the problem. The files it won't copy from my external HD to the SSD on the SK seem to be randomly chosen!!
Might they be "copy protected", and if so any ideas how I unprotect them?
Cheers
PhilipAC
« Reply #2 on: 9 Jan 2017, 03:16 pm »
Problem solved! I needed to amend permissions on the relevant files.
astrotoy
« Reply #3 on: 5 Jul 2018, 04:42 pm »
I've just purchased a new used GG, being shipped from Lampizator in Poland. It has 512DSD capability and will connect to my computer with USB.  I currently have a Roon/HQP set up on my computer for my current DAC, which is an ethernet DAC (NADAC mch) which I will continue to use for my mch files.  Could you tell me the settings you use on HQP to connect to the GG?  I will be upconverting my DSD files to either 256 or 512.  I have quite a few DXD352 files and lots of PCM192 files that I will probably keep native.  Thanks,  Larry
