0 Members and 1 Guest are viewing this topic. Read 2583 times.
I recommend a unit w/ an ECM motor, essentially variable speed. This will allow you to have better control of humidity in the summer.Also, I have a Carrier Infinity system @ 20 SEER. I saw a break on the electrical in the summer, but not much difference for gas in the winter w/ a 90% furnace.The price seems fair, that size furnace is probably $800 - 900 w/ a 30% mark up and then the rest on install.Good luck!
20,000Kw heating unit, four ton A/C.
Heat is running !!!
Sorry it's 80,000 btu at 96 % efficiency .
20,000 kW is a lot of watts (20 million). You must have a bodacious electrical service (> 80,000A)! Steve
