Any tweeter recommendations?
0 Members and 1 Guest are viewing this topic. Read 1634 times.
bcbud3
« on: 24 Nov 2016, 04:54 am »
One of the morel tweeters is dead in my mini tower iia.  Is there a replacement/upgrade i can use or look around to buy?
7x57
Re: Any tweeter recommendations?
« Reply #1 on: 10 Dec 2016, 08:45 pm »
Madisound will recommend replacement drivers if you go to their website and submit all pertinent information that they request.
ST86
« Reply #2 on: 15 Dec 2016, 05:45 pm »
Hi,
You have to replace the tweeter with identical model, otherwise it will affect the crossover frequency.  Acoustically if a different driver is more or less efficient that will change the tonal balance.
Can you see which model Morel you have? Is it MDT-29?  Madisound has MDT-29 voice coil replacements and whole drivers, in both 4 and 8 ohms.
Ed
bcbud3
« Reply #3 on: 20 Dec 2016, 09:47 pm »
It ended up being cheaper for me to purchase 2 new dayton audio tweeters.  DC28F-8.  They seem to be very similar in specs if I'm not mistaken.  I will swap face plates and bolt them in.
Stimpy
« Reply #4 on: 21 Dec 2016, 01:16 am »
Please report back when you've swapped in the new tweeters, as I'd like to know the outcome  Hopefully, you'll like the results, and the Dayton tweeters can be included as acceptable replacements VMPS parts.
