What power supply?
0 Members and 1 Guest are viewing this topic. Read 1951 times.
yyz
What power supply?
« on: 16 Nov 2016, 04:03 pm »
I have a microRendu with the default power supply. I want to buy the SonicOrbiter for a lesser system in the house. What would you choose as the power supply:
1) The Linear power supply for the orbiter
2) The Standard power supply for the orbiter
3) Use the mircoRendu's power supply for the orbiter and upgrade the power supply for the mR (if this is possible)
What are there 2 choices for the lower priced orbiter power supply?
Thanks.
yyz
Re: What power supply?
« Reply #1 on: 16 Nov 2016, 10:57 pm »
I meant to say "Why are there 2 choices for the lower priced orbiter power supply?"
vortecjr
  • the sound has to be in concert with the music....
    • Sonore by Simple Design
« Reply #2 on: 17 Nov 2016, 12:16 pm »
You can't mix and match the PS between the Sonicobiter SE and microRendu. The Sonicobiter SE uses only 5VDC and the microRendu uses 6-9VDC. If you are buying the Sonicobiter SE get either PS. The different PS options are for different tastes.
yyz
« Reply #3 on: 18 Nov 2016, 01:52 am »
Thanks.
What is the more popular default power supply people are ordering for the Orbiter?
