Sonicorbiter - SonoreUPnP Bridge (beta)
0 Members and 1 Guest are viewing this topic. Read 1801 times.
vortecjr
  • the sound has to be in concert with the music....
    • Sonore by Simple Design
« on: 16 Nov 2016, 11:27 am »
DESCRIPTION
"Roonify" your DLNA/UPNP devices. The SonoreUPnP Bridge allows you to use Roon or Roon / Tidal to stream to DLNA/UPNP devices.
SPECIFICATION
- Gapless playback with Roon Server
- Selectable final stream types - LPCM or WAV
- Selectable maximum stream sample rate
- File Formats - typical file formats supported by the server
- Transmission from server to Sonicorbiter is Squeezebox protocol
- Transmission from Sonicorbiter to DLNA/UPNP device is UPNP protocol
- PCM Sample Rates with Roon Server - up to 192kHz PCM
- DSD Sample Rates with Roon Server - DSD64 via DoP, DSD128 converted to PCM
flow diagram
AVAILABILITY
The SonoreUPNP Bridge application is available on the following hardware:
Sonicorbiter SE, microRendu, microJukebox, and sonicTransporter series
LICENSING
Copyright © Simple Design, LLC
Click here for additional information:
http://www.computeraudiophile.com/f26-sonore-sponsored/sonicorbiter-sonoreupnp-bridge-beta-30468/
« Last Edit: 2 Feb 2017, 11:39 am by vortecjr »
