Sonore MicroRendu and Uptone Audio Ultracap LPS-1
0 Members and 1 Guest are viewing this topic. Read 2216 times.
sgr
Hi,
Wondering which Herbie's products would work best to isolate these two pieces. Maybe some Baby Booties and ultrasonic stabilizers and stack them together.
These small products create problems as they are small and light weight and often the USB and Ethernet cables move them around.
I'm hoping for some creative ideas. I have a Lampi Golden Gate DAC, Bluejeans Ethernet cables and the two short pieces of Curious USB cable.
Thanks for your ideas.
Steven
Herbie
    • Herbie's Audio Lab
Re: Sonore MicroRendu and Uptone Audio Ultracap LPS-1
« Reply #1 on: 3 Nov 2016, 08:17 pm »
Hi, Steven. Four Baby Booties w/adhesive underneath each component would be ideal. A SuperSonic Stabilizer on top additionally beneficial. Though stacking the units shouldn't be overly problematic sonically, I'd avoid stacking them if possible. (For the DAC, four Tenderfoot isolation feet and a damping instrument for each of the vacuum tubes would most likely be worthwhile.)
Herbie's Audio Lab
