0 Members and 1 Guest are viewing this topic. Read 23502 times.
more to research....
What else? I'm also reading a lot of good things about the Allo reclocker board that supposedly will reduce jitter and improve sound. I haven't heard one myself yet but you can read more about it in the mamboberry thread on diyaudio. Here's also a good introduction: http://www.dimdim.gr/2016/09/kali-fifo-buffer-reclocker-for-sbcs/
$90 for streamer/player/DAC is highly intriguing, but have zero DIY skills for this kind of stuff. (For me, running a computer to the DAC equipped with a remote control is a stretch into high tech.) Is this gear really, really, really operationally stable?
Hifiberry sells a steel enclosure as well as a plexi one.I have DIY (well, kit-building) experience but, as I recently discovered, not good enough close range vision to deal with boards involving surface-mount parts (or IT chops to navigate in the Linux command line)
@Odal3, I ordered a Kali with the Piano DAC. Thanks for the reminder Mambos are out of stock, perhaps something to try later.
Is there any case combo if you add the dac/reclocker or even just the MAMBOBERRY LS DAC+ ?
Also in regards to the reclocker - Kali will not work if your DAC is a master. Dac has to be slave.How does one know the difference....
