SPATIAL AUDIO - X1 UNIWAVE INTRODUCTION
0 Members and 1 Guest are viewing this topic. Read 33499 times.
Spatial Audio
Re: SPATIAL AUDIO - X1 UNIWAVE INTRODUCTION
« Reply #200 on: 6 Dec 2017, 11:28 pm »
Anyone know the thread size of the footers?
Yes - the thread size is 3/8-16
Clayton
pawsman
« Reply #201 on: 13 Dec 2017, 10:52 pm »
Clayton,
Could you double up the 18's, increase the sensitivity and do a passive version of the X1?
pawsman
Spatial Audio
« Reply #202 on: 14 Dec 2017, 03:05 am »
Clayton,
pawsman
The 18 inch woofer is a dual voice coil design, running parallel at 4 Ohms. So you can't gain sensitivity by adding a second woofer because parallel would make the speaker 2 Ohms and series connection would yield an 8 Ohm impedance but have the same sensitivity. So you would really need 4 woofers to play that game. A better approach is to create a passive network, using an autoformer to match the horn level to the woofer.
Clayton
