Audio Physic Tempo IIIi 65lb speakers and threaded gliders
0 Members and 1 Guest are viewing this topic. Read 1817 times.
davidavdavid
  • Music lover first, gear head second.
    • david.com
Are the M8 threaded studs the correct ones for my speakers? And as to length of stud am I best with the longest 40 mm?
Thanks in advance.
Herbie
    • Herbie's Audio Lab
Re: Audio Physic Tempo IIIi 65lb speakers and threaded gliders
« Reply #1 on: 2 Oct 2016, 05:17 pm »
They're most likely M8. If unsure of the thread size, however, it's always best to take one of your stock spikes to a hardware store and match it up with a known bolt or nut size. Either 20mm or 40mm length will be ideal; 40mm gives you more latitude for leveling on an uneven floor or for a little tilt.
Herbie's Audio Lab
davidavdavid
    • david.com
« Reply #2 on: 2 Oct 2016, 08:02 pm »
Just ordered 8 of the decoupled brass spike shoes/gliders. Looking forward to them.
