Amp biasing again...
0 Members and 1 Guest are viewing this topic. Read 13276 times.
germay0653
Re: Amp biasing again...
« Reply #40 on: 7 Feb 2017, 08:49 pm »
PM sent!
hifimonk
« Reply #41 on: 8 Feb 2017, 03:35 am »
Cor0086
« Reply #42 on: 28 Feb 2017, 03:00 am »
Can I get a copy also?
I just purchased a second hand khartago se
germay0653
« Reply #43 on: 2 Mar 2017, 03:20 am »
PM Sent!
Cor0086
« Reply #44 on: 2 Mar 2017, 03:22 am »
mtho33
« Reply #45 on: 6 Mar 2017, 07:12 am »
germay0653 - can you PM me biasing instruction? I have just purchased second hand Odyssey Mono Extreme (upgraded to Kismet).
Thank you.
erniek
« Reply #46 on: 18 Mar 2017, 05:03 pm »
I just had a dedicated line installed for my Khartago and am wondering if it needs to be re-biased?
TJHUB
« Reply #47 on: 18 Mar 2017, 05:37 pm »
Since you're incoming voltage hasn't changed, no re-biasing should be necessary.
johnzm
« Reply #48 on: 21 Mar 2017, 01:26 pm »
could someone pm me the instructions? the last set of instructions i got was somewhat confusing and after probing and seeing wild numbers i did not trust myself to turn the right knobs to fix it.
EquinoxDesignLab
« Reply #49 on: 21 Mar 2017, 04:52 pm »
Hey Germay, could you send me the instructions as well? Curious to see where my Stratos lies. Thank you very much!
ldandha
« Reply #50 on: 21 Mar 2017, 10:23 pm »
Hi Germay, would you please send me the biasing instructions as well.  Thanks in advance!
germay0653
« Reply #51 on: 21 Mar 2017, 11:25 pm »
PM's, with instructions, sent to johnzm, EquinoxDesignLab and Idandha!
Audionautic
« Reply #52 on: 31 Mar 2017, 11:31 am »
Hi Germay-
Please send me the details for Stratos Monos biasing when you can? Many thanks!      -Tom
germay0653
« Reply #53 on: 1 Apr 2017, 02:50 pm »
PM sent!
David C
  • Don't try and lay no boogie woogie on the king
« Reply #54 on: 1 Apr 2017, 03:01 pm »
At the risk of sounding like I know what I'm talking about, would it not be easier to have a biasing link on the Odyssey website to give instructions? BTW I  unfortunately don't own an Odyssey but have heard the amps at an audio show and they are really great amps, very well built and sound way above their price point by far.
germay0653
« Reply #55 on: 3 Apr 2017, 01:20 am »
That would be up to Klaus!
rikhav
« Reply #56 on: 3 Apr 2017, 02:56 am »
Hi germay
Can you PM me as well the instructions to rebias the amp
I have a stratos extreme stereo. My power supply is 230 volt so do I have to follow a different set of readings?
germay0653
« Reply #57 on: 5 Apr 2017, 02:27 pm »
PM sent.  I don't believe the board voltages change based on the main input voltage but you should check with Klaus to validate that.
rikhav
« Reply #58 on: 5 Apr 2017, 08:19 pm »
Thank you so much
I also have same opinion as you about voltage , still will try to call Klaus and confirm the same
johnzm
« Reply #59 on: 14 Apr 2017, 12:19 pm »
so if they are monoblocks, there are two knobs inside the case that adjust the bias. the instructions do not mention this. is there any additional info on setting bias for monoblocks?
