0 Members and 2 Guests are viewing this topic. Read 6038 times.
Pretty small max linear excursion, too. "...somewhat throaty tone..." hmmm—could that be connected with the 10 dB peak at 2kHz?
Seems there is other 15 inches driver souited to OB in Eminence line:http://www.parts-express.com/eminence-red-coat-big-ben-15-guitar-speaker-225w-8-ohm--290-860http://www.parts-express.com/pedocs/specs/290-860--eminence-red-coat-big-ben-specifications.pdfLooks even better than Alpha15A:-Overall sensitivity is 101.3dB-On OB range til 300Hz sensitivity around 98dB, greater Alpha-price $110-QTS 0.94 lesss extreme than AlphaBig Ben Red Coat 15 inchesNominal Basket Diameter 15.0'' / 381mmNominal Impedance 8 ohmsPower Rating 225WUsable Freq Range 70Hz - 3.5LHzSensitivity 101,3dBMagnet Weight 56 oz.Gap Height .375'' 9,5mmVC Diameter 2.5'' - 64mmThiele & Small ParametersResonant Frequency (fs) 85 HzDC Resistance (Re) 6.06 ΩCoil Inductance (Le) 0.51m HMechanical Q (Qms) 10.63Electromagnetic Q (Qes) 1.04Total Q (Qts) 0.94Compliance Equivalent Volume (Vas) 77.7 liters / 2.74 cu.ft.Peak Diaphragm Displacement Volume (Vd) 0 ccMechanical Compliance of Suspension (Cms) 0.08 mm/NBL Product (BL) 12.1 T-MDiaphragm Mass Inc. Airload (MMs) 47 gramsEfficiency Bandwidth Product (EBP) 82Maximum Linear Excursion (Xmax) 1 mmSurface Area of Cone (Sd) 856.3 cm2Maximum Mechanical Limit (Xlim) N/AContructionCopper VCPolyimide FormerNon Vented CorePressed Basket SteelPaper Cone Zurette Dust Cap
"How much is Mms?I could not found this value. "According to the specs you posted, MMs is 47 grams, but I was talking about xmax and associated Vd (in maroon, above). I'm sure xmax is more than zero, but this driver still does not seem to be destined for successful use as an OB woofer. As nicoch pointed out, fs is 85Hz.
Oh too bad.
Would this woofer be good for a open baffle sub? https://www.parts-express.com/visaton-ws25-e-10-paper-cone-woofer-8-ohm--292-598
