Verdier Turntable
0 Members and 1 Guest are viewing this topic. Read 2011 times.
vinylvalet
Verdier Turntable
« on: 8 Sep 2016, 11:21 pm »
I'm helping a friend install a new cartridge in his Verdier/Morch turntable/tonearm. This turntable was originally on an air suspension table so we used solid footers to couple the table to that platform. He has moved the turntable to a more rigid platform system, Naim Fraim. Which of the Herbie products would be best suited between the turntable and this new platform? The Verdier turntable has a thick granite plinth with the platter magnetically levitated. Thank you.
vinylvalet
Re: Verdier Turntable
« Reply #1 on: 9 Sep 2016, 08:02 pm »
A search of the archives indicates that four big tall extra firm Tenderfeet might be the best solution.
The metal armboard pilar is rigidly coupled to the granite base. Perhaps a .8mm Grungebuster sheet between the two surfaces may result in additional improvements. Any thoughts on all this?
Herbie
    • Herbie's Audio Lab
« Reply #2 on: 10 Sep 2016, 02:24 am »
Four Big Tall Extra-Firm Tenderfoot isolation feet should be ideal under the turntable. Between the armboard pillar and plinth, grungebuster material makes an excellent and beneficial isolation/decoupling interface, whether 0.8mm or 1.6mm-thick, either sheet material or Dots.
Steve Herbelin
Herbie's Audio Lab
vinylvalet
« Reply #3 on: 10 Sep 2016, 09:01 pm »
Thanks Steve.
