0 Members and 1 Guest are viewing this topic. Read 4706 times.
Hello!I am new to this forum. I have ordered a LIO.Configured as :InputsAVC/TubestageDAC with microrendu powersupplymosfet AMPHave lurking around a great deal before I took the opportunity to order this integrated that I look forward to hear.I enyoy the help from Vinnie that was prior to my final decision to order one. I live in Sweden so a bit costier with custom fee and TaxesAnyway I have not read so much about the VR120. Are there anybody who have upgraded from the small module to this one. Can one apart frommore power also expect better SOUNDQUALITY with this one in favour of the small module?Regards MagnusI am driving 89db efficient Spendor F l9's tin a 14 x 19 family room that opens into a breakfast nook and large kitchen that measures another 25 ft and I have plenty of power with the 25 watt mosfet amp.I agree with jwtrace that the DHT Pre is the ticket if budget allows. I upgraded from the AVC/Tubesstage ...which is awesome in its own right .... but the DHT Pre is in another league.
I was thinking that I should try out ROON today. I have a microRendu which is already ready for this application.I signed up for a trial period of 14 days. But it will definately stay - a little expensive but soundquality raised quite a bit compared to J-river using the same computer as a DLNA server. I think this computer audio never seize to amaze or surprise you. That a setup and software canmake such a difference. Makes me wonder if not it was better just using a CD player in the old days where one did not have to tinker at all.What do you guys use for source with your LIO.If you are using computer audio and especially with microRendu - how is your setup look like?All the best from SwedenMagnus
Windows Desktop/Roon (not in music room)->microRendu_>LIOI was previously using JRiver on a dedicated and purpose built Windows desktop that was in the room.I was able to improve the sound and remove the computer from the listening room!! George
Hi Magnus,I have been really enjoying Roon as well!Here is how I am doing it:Macbook Air (wireless) / Roon >> Airport Express (CAT 6A out) >> microRendu >> LIOVinnie
The LIO arrived today.It is really an impressive build. Pictures on it don´t really justify it. Very nicely built together. Volume nevere exeeds 32 - its loud enough. Another positive surprise.Thank you Vinnie for a real winner,Regards Magnus
The LIO arrived today.It is really an impressive build. Pictures on it don´t really justify it. Very nicely built together. It sounded pretty impressive from cold too. I guess it needs some burn in? I switched after a couple of hours to the Belleson regulated powersupply formy microRendu and this was very clear that my older Teddy pardo was better initially, after some hours the Belleson also start to sing. I am still using my Didit dacbut I am very courious to try the LIO dac too. Its nice to easily hear the differences with the LIO, its that transparent and surprisingly weighty sounding. Much ballsier thanmy old 100 watt monoblocs from Teddy pardo. Volume nevere exeeds 32 - its loud enough. Another positive surprise.Thank you Vinnie for a real winner,Regards Magnus
That said I typically listen at fairly low levels so I'm not sure how big of a difference I need; toddlers around the house tend to limit my rockin' out.
Hi matthewpartrick,If this is the case, you will be fine with the LIO MOSFET AMP.I've run Harbeth SHL5+ and 40.2s (around the same sensitivity/impedance) at audio shows with LIO MOSFET AMPand levels much louder than "fairly low levels" - no problem at all Vinnie
Hi!After receving the LIO with its 25 watt mosfet amp I am convinced that I don`t need more power for now. I use standmounts speaker 86 db/w sensitivity.So the best way to go for me is probably the DHT but first I will enjoy my LIO and hear and explore records again.I read with interest the DHT thread and about wich tubes to use. I would appreciate the most neutral ones though. I guess the ones that Vinnie include in the package.All the bestMagnus
