0 Members and 1 Guest are viewing this topic. Read 45684 times.
I have the M3 Turbo S and my room is 17 ft wide X 32 feet long. It fills the room and then some. I have a Class D Audio SDS-470 with 600 watts per channel into 4 ohms. The system can go louder than I can handle with absolutely no distortion. My friends get a kick out of how loud it can get, but always comment on the clarity/clearness of the sound. This speaker is a beast. I heard the Magico Q3s at a friend's house and I enjoy my Spatials more.
freemand nice post , we have two really different design , the coax based on an old 50year design ,copy of Tannoy but with cheaper unit ,yes only cheaper unit use a stamped frame , that is crude classic two way xover design with all the problem that all know, Altec have a rich story on coax (sorry Anand but that waveguide is the cone and is not fixed! you forget that little details ..the most important one !) Howerton audio is here from a lot year and serve diy well if you like compression driver or find the original Tannoy gold unit On the other side we have a new concept DIY friendly ,a FAST concept with some full range unit ,no xover in sensible zone or no xover at all if you use biamp with a fantastc 15" aluframe ,neo motor with copper ring .
Thanks for the feedback! I have heard from other sources too that M3 TS has no issue filling up big space. I was more interested in knowing between M3 and Trio 15, which would be more suitable for small-medium sized room.
What do you consider a small-medium room?There are tons of great reviews on the M3's from shows in hotel rooms- which I would consider small-medium.George
Around 16'Lx12'Wx9'H. I actually heard from Clayton that M3 would be more suitable than M4 for me. I guess, my question is more around the suitability of Trio 15 in a similar sized room.
Ok then......how about a comparison of the M3 turbo S and GR Super V ?I own a pair of Super V and soon the Trio with the TB 1808.....I can compare these two, buthave never heard the Spatial.I'm sure a few of you have laid ears on the M3/4 and Super V I'd like to know your thoughts.
