BG Radia FS 880's Planars For Sale
0 Members and 1 Guest are viewing this topic. Read 1780 times.
faxer
« on: 24 Jul 2016, 02:36 pm »
These are very special custom planar magnetic speakers specially built for me in collaboration with Igor Levitsky the then lead audio engineer at BG Radia and Danny Ritchie at GR Research. They are in excellent condition and come with a custom crossover featuring Jupiter Cast copper capacitors,Duelund Inductors and Path Audio Copper resistors. The crossover alone is woth $10,00.00.They are simply Maggie killers please see Dr. Sakakini's video on You Tube and our video for these speakers under BG Radia FS 880 For Sale or https://youtu.be/czumOZMG1yM. These speakers also come with a specially designed methacrylate wing and 1,000 watt volume.adjustable bass amplifier. They are retailed at $45,000 and are offered at only $18,000-the crossover alone is 10k. Please message me if you have any questions.
The FS-880 dipole speaker system is one of the first full-range freestanding speaker designs in the BG Radia family of products. With the FS-880 we have taken the award winning Radia LA-Series in-wall designs and crafted them into an incredibly dynamic floorstanding system; a system that both compliments our current line-up, and is a prime example of what can be expected of our speaker systems. This magnificent hybrid design is comprised of an array of 16 Neo3-PDR planar ribbon tweeters in a dipole configuration (an open back tower that helps to reveal the life-like detail and deep realistic breadth of the sound stage), an array of 6 dipole Neo10 planar ribbon midrange drivers (again, open backed for a fuller, more spatial sound), and 4 hi-output sealed 8” double-gap paper-composite woofers which are actively driven by 2,000 watts of class-D amplification. One of the distinct features of the FS-880 is that its midrange line array section operates without the encumbrance of a high pass filter, which allows for the superior reproduction of a greater vocal range. The Neo10 drivers are connected in series for a total of 40 ohm resistive load capacity. With this capacity, the array delivers an amazing 93 dB/2.83V. This allows for very high SPL peaks without overloading the amplifier’s power supply. In other words; the FS-880 allows any amplifier to work at its best theoretical capability and maximum dynamic range without overload and distortion. The absence of capacitors in the signal path of Neo10 array provides direct drive of the midrange section with the utmost transparency and resolution. In combining all of the elements of the open backed array, the neo3 tweeters, the robust nature of an unharnessed array of neo10 midrange drivers, plus the piston action of the actively driven 8” double-gap woofers, the FS-880 reveals a speaker system that is unmatched in performance. And, when combined with our traditional Radia Series woofer enclosure, heavy steel base and metal cone feet, this monumental arrangement stands as a breathtaking beautiful 83in (2.11m) tower.
Radia Series FS-880 Full-range active Speaker System: Tweeters: BG Radia Neo3-PDR 3” planar ribbon, patented driver technology. Midrange: BG Radia Neo10 - 10” planar ribbon, patented driver technology. Woofer: BG Radia 8” double-gap paper composite, proprietary driver technology. Crossover: High performance passive crossover network using Duelund inductors and Jupiter cast copper capacitors and Path Audio copper resistors. Tower: Automotive Hi-Gloss painted high tensile strength Aluminum alloy extrusion. Tweeter & midrange panel: ¼” plate from high tensile strength Aluminum alloy CNC machined plate. Woofer enclosure: Automotive black satin 1” MDF sealed and heavily braced. Input terminals: 3 pairs, WBT. Retail Selling Price scheduled at $35,000.00 US
› GENERAL PARAMETERS: System type Three-way, line array floorstanding loudspeaker, bi-amplified. Two woofer amplifiers included. System dimensions (H x W x D) 83” x 11 5/8” x 24 3/4” (211.0 x 29.4 x 62.9 cm) Weight 95 lbs. (43.2 kg) › DRIVER COMPLEMENT: LF 4 x 8” dual-gap long-throw woofers in force cancelling configuration MF 6 - Neo10 planar ribbon line-array HF 16 - Neo3-PDR planar ribbon line-array Crossovers 200 Hz, - active, woofers only; 1.5 kHz - 2nd order Linkwitz-Riley Frequency response 25 Hz - 20 kHz (-6 dB, di-pole) Power handling: Woofers 500 W (AES) 1000 W (long-term IEC 60286-5) MF-HF array 600 W (AES) 1500 W (long-term IEC 60286-5) Nominal impedance: Woofers 2 x 8 ohms MF 40 ohms, resistive HF 4 ohms, resistive Sensitivity 93 dB/2.83 V/1m Max SPL 120 dB/1m (band-limited pink noise, C-weighted) › BG RADIA A-3 AMPLIFIER: Rated power 2 x 500 W RMS (1 amplifier per tower) S/N ratio (20 Hz - 20 kHz) > 95 dB THD + N (500 W, 20 Hz - 1 kHz)
