I listened to a megabuck turntable... SHOOTOUT! *Part 3 - updated*
0 Members and 1 Guest are viewing this topic. Read 26065 times.
rob400
  • Versalex and Audio Note for the rest
It would be nice to have access to lots of high end gear for home dems before purchases Simon but the reality is that its logistically impossible as you will know. I've yet to meet a dealer who will recommend something they don't sell over something they do to direct to worthy alternatives and  ultimately MY ears make the buying decisions as it were so I will have to narrow considerations down to just a few.
I have a buyer for my Versalex and it would seem like the obvious next component to look at with it being a £4k deck in a £150k at retail system. But my 21g AN IO Gold cartridge is currently singing sweetly in it so nothing spoiling until I can compare against a 400/ Kronos or whatever else seems worthy and accessible. If the 400 builds on the Versalex/Amadeus strengths whilst adding weight and authority it will be a hard act to follow IMO.
By the way I would liken the move to valves from transistors as the move from LP12 to WT. I play more albums/genres because of the less processed sound with just a small percentage not as thrilling as before........
Kimiimacman
That is precisely what the 400 does. Bill has managed not to make an entirely different sounding deck but to build on his previous strengths. High mass decks usually differ considerably from the lighter options but the 400 builds on the sence of air and flow whilst adding considerable authority. John Bonham and JPJ have never sounded so 'heavy', as when I had the 400 home, not even with my Naim 500 system and a tricked up LP12. By comparison the Versalex sounds a tad soft and slow, I kid you not. A straight a+b and I'm gutted tbh. The perils of working with this stuff. Nothing I can do gets the Versalex anywhere near the 400 and I have tried. Removing feet, using Still Points, myrtle wood blocks, Sorbothene spheres and various bases, all change the sound to some degree but none add that bottom end the 400 does so effortlessly. Once heard never forgotten. Bugger.
I agree totally with your last point, my experience precisely.
ATB
Simon
« Last Edit: 21 Nov 2017, 11:03 pm by Kimiimacman »
G E
Really liking my WTA these days, but because a hobby is not a hobby unless it involves obsession,i asked Mike Pranka if we can expect a Royale 300 at some point in the future. "Not likely" was the unfortunate reply.
But i have made some changes that bring my system to a new level:
Cables.
I have used Morrow cables for several years and liked their speed and transparency. But they seemed a little light overall.   So i moved up 3 levels for the phono cable (ph-7) and IC from phono to preamp (ma-7). I also snagged a barely used pair of speaker cables (elite grand reference) at a nice price, also Morrow.
After many hours on the cable cooker i can say this is a most worthy investment!  Sound is fuller, percussive instruments better defined, better decay and speed remains intact. 3d imaging is spectacular and it was already darn good++.
I am also dumbfounded at the difference made by Cardas M power cables on Bel Canto preamp and Hagerman phono. Why should the last 1.5 meters of power delivery make such a difference?  But it's there for the hearing.
I also bought 4 new 6.5" mega woofers for my Brian Cheney designed VMPS RM 30 speakers. I performed the series 2 upgrade a couple years ago and decided to do the specified woofer upgrade while i can still get the drivers.
They are in house and i am waiting for complete cable burn in before i start. I want to know my reference point.
I still go down the street and listen to the Transrotor turntable.  That is a fine piece of kit. Our Well Tempereds have a low noise floor but this betters it. He's done some tweaking and cable changes and his all new VAC stack is burned in.  The overall sound is much improved. Ive spent a number of hours in the sweet spot sipping 12and sometimes 18 year old scotch and it is a very pleasant experience.
I prefer the electricity my system generates. No doubt he prefers his. And that is fine. Two completely different approaches to music reproduction that sound completely different. And both are wonderfully entertaining!
« Last Edit: 11 Feb 2018, 04:44 am by G E »
