Bryston BDP-Pi
0 Members and 1 Guest are viewing this topic. Read 48131 times.
unincognito
    • bryston.com
Re: Bryston BDP-Pi
« Reply #40 on: 17 Aug 2016, 12:11 am »
Ok so a thumb or flash drive will not work the May or may not in the manual had me confused.. I was thinking a thumb drive would but a hard drive would not...
A thumb drive would likley be fine, but once you get into bus powered hard drives and solid state drives(not to be confused with thumb drives), then it becomes a problem with the mpd-2 and ps-3
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston BDP-Pi
« Reply #41 on: 17 Aug 2016, 12:14 am »
Hi
I would recommend just to use the wall wart power supply with the Pi then all options are available.
James
unincognito
    • bryston.com
Re: Bryston BDP-Pi
« Reply #42 on: 19 Aug 2016, 10:09 pm »
We inch ever closer
Re: Bryston BDP-Pi
« Reply #43 on: 1 Sep 2016, 02:52 pm »
Hi Gents,
I received our sample Bryston Pi digital yesterday and  want to say how pleased we are with the fit and finish.  Congrats.
As part of Bryston theatre we have a BDP-2 and BDA-3.
In the great room, we will be installing the Pi, 4B Cubed Amp and BP-6 with DA.
Dan Saso
Enterra Inc
MadScientist
Re: Bryston BDP-Pi
« Reply #44 on: 13 Sep 2016, 09:48 am »
I'm interested in the pi to add a lower cost Roon-enabled zone.    I notice the Pi has an IR output option.  Is there any chance this could be configured to control non-Bryston stuff (Ideally, I would like the Pi to feed my Meridian F80 and control it's volume).   Thanks
Samurai7595
Re: Bryston BDP-Pi
« Reply #45 on: 13 Sep 2016, 12:48 pm »
Can the BDP-Pi be controlled by the MPaD app via the Apple iPad?
Re: Bryston BDP-Pi
« Reply #46 on: 13 Sep 2016, 01:10 pm »
Hi
Yes  it  can
vegasdave
Re: Bryston BDP-Pi
« Reply #47 on: 14 Sep 2016, 05:21 am »
Hi JP
The Pi is powered by a wall-wart power supply only.  The BP-2 MM Phono and the BP-2 MM/MC phono stage is powered by the PS3 and we hope eventually by the MPS2 (working on it.)  The TF2 is a transformer step-up so it is passive and does not require a power supply.  It is designed to raise the output of the MC cartridge to the point that a normal MM Phono stage can use it.  If you have a MC and a MM cartridge then the BP2 MM/MC unit is the better option because it is all in one unit but it also needs the PS3 power supply.
james
is the mm stage similar to the 1 in the bp6?
Re: Bryston BDP-Pi
« Reply #48 on: 14 Sep 2016, 08:31 am »
Hi
Similar but there has been a number of changes.
james
Jpktenere
Re: Bryston BDP-Pi
« Reply #49 on: 25 Sep 2016, 11:55 pm »
I have had the pie on order for a couple weeks know getting excited that it might show up soon any word when they might hit the streets? Any body have any user feed back yet! How does it sound? How is the interface working?
Re: Bryston BDP-Pi
« Reply #50 on: 26 Sep 2016, 10:54 am »
Hi
We have shipped about 30 units so far and have about 80 on backorder.
james
Jpktenere
Re: Bryston BDP-Pi
« Reply #51 on: 26 Sep 2016, 08:01 pm »
Good to here hopfully mine shows soon! As for those 30 any comments out there???
schmidtmike76
Re: Bryston BDP-Pi
« Reply #52 on: 9 Oct 2016, 02:03 am »
Just ordered mine can't wait for a proper front end.  Happy thanksgiving everyone
« Last Edit: 21 Oct 2016, 06:52 pm by schmidtmike76 »
Dan Twomey
Re: Bryston BDP-Pi
« Reply #53 on: 10 Oct 2016, 08:25 pm »
I've had mine for a few weeks now. One small disappointment. My DAC is not compatible with the Pi's USB port. I'm restricted to SPDIF. I have an Eastern Electric DAC as mentioned in the following article, http://www.enjoythemusic.com/magazine/equipment/1212/eastern_electric_minimax_dac_plus.htm
Dan
tie_breaker
Re: Bryston BDP-Pi
« Reply #54 on: 10 Oct 2016, 09:03 pm »
Dan how do you like the sound of the Pi via SPDIF?
thx..
Dan Twomey
Re: Bryston BDP-Pi
« Reply #55 on: 10 Oct 2016, 10:30 pm »
thx..
I haven't had a lot of time with it yet. First impressions are that it's very good. Like any audiophile I have my biases and perceptions. My Peter Daniel Shigaclone (which I just sold) was exceptional but like any single disc transport wasn't very convenient.
Dan
Re: Bryston BDP-Pi
« Reply #56 on: 11 Oct 2016, 04:28 pm »
schmidtmike76
Re: Bryston BDP-Pi
« Reply #57 on: 11 Oct 2016, 07:10 pm »
which cable do you prefer so far James coax or the USB.  I have a BDA-2
Re: Bryston BDP-Pi
« Reply #58 on: 11 Oct 2016, 07:25 pm »
HI
I am using COAX.
james
matthewpartrick
  • thecluelessaudiophile.com
    • The Clueless Audiophile
Re: Bryston BDP-Pi
« Reply #59 on: 13 Oct 2016, 03:53 am »
What does the bdp2 do that the bdp-pi doesn't?  Different file support and different power supply?  I was thinking running the bdpp off the Vinnie Rossi ultra cap power supply.
