Bryston BDP-Pi
0 Members and 1 Guest are viewing this topic. Read 57064 times.
  • The Demo is Everything!
    • http://www.bryston.com
Bryston BDP-Pi
« on: 6 Jul 2016, 11:27 am »
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
Re: Bryston BDP-Pi
« Reply #1 on: 6 Jul 2016, 01:49 pm »
Nice!!!
Grant Hill
Re: Bryston BDP-Pi
« Reply #2 on: 7 Jul 2016, 12:05 pm »
really nice indeed
does it support DSD files?
Re: Bryston BDP-Pi
« Reply #3 on: 7 Jul 2016, 12:54 pm »
really nice indeed
Hi
No DSD.  Have to go to the BDP2 for that.
James
Pundamilia
Re: Bryston BDP-Pi
« Reply #4 on: 7 Jul 2016, 05:15 pm »
Slightly OT. I just upgraded to a BDP-2 this week. I have a BDA-1. Do I need to upgrade the DAC to convert DSD files or am I okay with the BDA-1?
Thanks.
Grant Hill
Re: Bryston BDP-Pi
« Reply #5 on: 8 Jul 2016, 08:09 am »
Hello,
you need the BDA-3 if you want to play DSD files. Highly suggested as it is a fantastic dac even with PCM.
unincognito
    • bryston.com
Re: Bryston BDP-Pi
« Reply #6 on: 8 Jul 2016, 01:57 pm »
really nice indeed
we won't prevent playing dsd files over USB to a DAC that supports it, but would not recommend it... at all
mnorman
Re: Bryston BDP-Pi
« Reply #7 on: 8 Jul 2016, 02:47 pm »
What is the MSRP in N.A. ?
Grant Hill
Re: Bryston BDP-Pi
« Reply #8 on: 8 Jul 2016, 02:48 pm »
#unincognito: Why do you think so?
Re: Bryston BDP-Pi
« Reply #9 on: 8 Jul 2016, 03:19 pm »
$1295
techguy0192
Re: Bryston BDP-Pi
« Reply #10 on: 9 Jul 2016, 12:02 am »
schmidtmike76
Re: Bryston BDP-Pi
« Reply #11 on: 9 Jul 2016, 12:57 am »
I have to ask do you think this unit would be on par with a transport at the same price or better in terms of resolution running into a bda-2
25x
Re: Bryston BDP-Pi
« Reply #12 on: 23 Jul 2016, 09:45 am »
I see there is also a version with black faceplate. Are there any pictures?
Re: Bryston BDP-Pi
« Reply #13 on: 23 Jul 2016, 10:46 am »
I do not think we have an black pictures but I will ask Chris.
james
Grant Hill
Re: Bryston BDP-Pi
« Reply #14 on: 23 Jul 2016, 11:52 am »
Hi,
why did you say so? I don't understand what you're meaning...
Soldeed
Re: Bryston BDP-Pi
« Reply #15 on: 23 Jul 2016, 12:53 pm »
Can you run 3rd party software on the BDP-Pi?
Re: Bryston BDP-Pi
« Reply #16 on: 23 Jul 2016, 12:58 pm »
It is Roon certified.
james
25x
Re: Bryston BDP-Pi
« Reply #17 on: 23 Jul 2016, 05:57 pm »
Hi,
Maybe means SPDIF will work better than USB.
Grant Hill
Re: Bryston BDP-Pi
« Reply #18 on: 24 Jul 2016, 08:51 am »
But 95% of Dac accept DSD via USB only... Bda3 also via HDMI... You cannot use SPDIF
25x
Re: Bryston BDP-Pi
« Reply #19 on: 24 Jul 2016, 09:39 am »
I think just Chris could explain his comment.
The question is how much guys really use DSD. I personally play 44.1 mostly.
Specs for my DAC (not Bryston) don´t mention DSD for SPDIF but I found DSD64 working perfectly.
This is through a homebuilt player using Pi2 and Hifiberry Digi+.
But I like BDP-Pi and hope to buy, depending what European shops will charge.
