Tube Dampers for 6C6 and 2A3
0 Members and 1 Guest are viewing this topic. Read 1854 times.
Docere
« on: 21 Jun 2016, 10:14 am »
Hi Steve,
What tube dampers and size would you recommend for the following ST-shape tubes:
  • 6C6 - 39mm at the shoulder (widest part)
  • EML 2A3 and JJ 2A3-40 - both 62mm at the shoulder
I prefer a sound that makes my toe-tap, is tonally well-developed, vibrant, and free of glare/ edge. Cost difference between products is not an issue.
I am thinking HAL-O III-65 would be best for the 2A3s and maybe the HAL-O III-40 for the 6C6, but thought I would check.
Ray
Herbie
    • Herbie's Audio Lab
Re: Tube Dampers for 6C6 and 2A3
« Reply #1 on: 21 Jun 2016, 05:17 pm »
Hi, Ray. HAL-O III-65 and HAL-O III-40 would be ideal for these tubes.
Best regards,
Robert Herbelin
Herbie's Audio Lab
Docere
« Reply #2 on: 21 Jun 2016, 07:36 pm »
Thanks for the confirmation Robert - that is what I will purchase.
Ray
