Got some dust/dirt on my mat...how to clean??
0 Members and 1 Guest are viewing this topic. Read 3399 times.
starkiller
« on: 24 May 2016, 08:15 pm »
Would like to know how to get some dust/dirt off my mat....vacuum?
S Clark
Re: Got some dust/dirt on my mat...how to clean??
« Reply #1 on: 24 May 2016, 09:17 pm »
I have to brush mine periodically, and it's not especially easy.  I'm eager to hear if there a better solution.
rajacat
  • Washington State
« Reply #2 on: 24 May 2016, 09:33 pm »
Try taking some blue painters tape, which has a very moderate adhesive, and use it to remove the dust/dirt. I've used it to clean my record brush and it does a good job and doesn't leave a residue.
Nick77
« Reply #3 on: 24 May 2016, 11:06 pm »
I thought you could wash with soap and water but haven't tried it yet??  :scratch:
Herbie
    • Herbie's Audio Lab
« Reply #4 on: 25 May 2016, 01:44 am »
With a Way Excellent, Way Excellent II or grungebuster turntable mat, the best way to clean the mat and keep it clean is to just dab the mat gently from time to time with a wide piece of masking tape. The mat can also be cleaned by gently wiping with a paper towel or cloth lightly moistened with distilled water, denatured alcohol, window cleaner or anti-static spray.
Steve Herbelin
Herbie's Audio Lab
advanced101
« Reply #5 on: 25 May 2016, 06:56 pm »
I use a lint roller.  Works perfectly.
Scottdazzle
« Reply #6 on: 25 May 2016, 09:49 pm »
The In the Groove record cleaner works great and is easier to use than masking tape.
Bishamon
« Reply #7 on: 26 Jun 2016, 11:57 pm »
Great suggestion!  I've just ordered one.  :)
