0 Members and 1 Guest are viewing this topic. Read 70743 times.
i've heard good things about the KR PX-4 but has anyone tried the KR 300B?
I don't even have my used DHT yet and I'm already planning tubes to try!
An update on the Elrog 300Bs, I have noticed that they can ring, I believe this is what is considered to be microphonic. The ringining is most noticeable when you stop a loud passage. I may try a cover over the tubes to see if that makes any difference. Just wanted to throw this out there for anyone who may be considering the Elrog.Best,Ed
Regarding KR, I have their PX-4 and 45. Both are excellent build quality. The PX-4, as many have mentioned before do about everything well with little noise or hum. They are reference tubes in my mind.The 45s are much warmer with better base extension and bit more noise and hum than PX-4, but nowhere near as noisy as the EML 45-mesh I have. The KR-45 are comparable to the RCA circa 1950 NOS I have in sound and noise. I prefer the KR 45 sound and they are less noisySomeday will write up a more detailed comparison of KR PX-4 and the assortments of the 45s I have
My question to Vinnie, based on my research of prior Elrogs failures: Is the current of LIO DHT Power Supply limited with soft start at Power up, or if you have implemented some sort of initial current limiting at start up?
Can anyone generalize that the 45's are more authoritative, with more solid tighter bass than the 300B or 2A3?or is it brand dependent?
In a power amp position or in a DAC?
I have an opportunity to purchase a new pair of Electro Harmonix 300b for Around $200. Can anyone say they are better than the EH 300B thatCome with the LIO?
I realize what the stock tubes are.Is it a waste of $200 to try the EH 300b ?
