0 Members and 1 Guest are viewing this topic. Read 3192 times.
what is the maximum height the component stack can be before they begin to compromise acoustics
Now it is said that the air space between the speakers should be kept as empty as possible, and that the audio components should be placed somewhere else in the room.That is the ideal set up.Now, lets say that you do not have a choice, and have to place your components between your speakers, what is the maximum height the component stack can be before they begin to compromise acoustics?Right now my equipment stacks about 28 inches (711mm) between my speakers.-Lost81
I must respectfully disagree with John on the use of foam in most circumstances. If you have a carpeted room (which is what I see in at least 90%+ of the music rooms here in the South), the use of SONEX is a no-no in almost every conceivable case . The carpet is already absorbing too much of the high frequencies and adding SONEX just makes it worse. For these cases, a diffuser is a much better alternative. If you have concrete/tile/wood floors, then John is correct and adding SONEX around the equipment as part of a comprehensive room treatment plan is a great idea. ..
When it comes to equipment placement, I totally agree with John Casler and Val. If you want the best possible sound and you have a properly designed room that will allow you to get it, the equipment should definitely go between the speakers. I have tested this extensively in my own state-of-the-sound demo room and symmetric placement and shorter speaker cables/interconnects always come out on top. However, I will agree that placement and the type of rack used is important....
There could be a bit of misunderstanding here, as SSS's between could be interpreted to mean very close to. Whatever the case is, I insist that the most common problem is represented by doug s' (whose ears I respect, by the way) speakers still not being far enough into the room (which in this case also means far from the equipment) for optimum soundstaging. Not bad at all, but perhaps improvable in what appears to be long-wall placement in a biggish room or short-wall placement in a very big room....
doug, 6 feet is more than enough and it is just the perspective that appears to show quite a bit less than that. Hey, I don't doubt what your ears tell you!Val
The goal of any professional designer is to understand all of this (and much, much more), understand the requirements of their client (i.e., is this for a church, mixing studio, recording studio, home playback environment, etc.), and then implement a compromise solution that best meets these requirements. ...
