BryFi
0 Members and 2 Guests are viewing this topic. Read 43033 times.
CanadianMaestro
Re: BryFi
« Reply #80 on: 10 Nov 2016, 06:58 pm »
Apple = The Grinch
  • The Demo is Everything!
    • http://www.bryston.com
Re: BryFi
« Reply #81 on: 10 Nov 2016, 07:26 pm »
Thanks James so I guess its safe to say it wont be available for xmass ?
HI
Fingers crossed as Apple said another 2 weeks.
We have a bunch on order so it would be nice to get them to people for their Christmas. :thumb:
james
pmcd
Re: BryFi
« Reply #82 on: 10 Nov 2016, 11:37 pm »
Thank you sir
Mike-48
Re: BryFi
« Reply #83 on: 28 Nov 2016, 07:12 pm »
Bubble UPnP is by far and wide the best DLNA UPnP android app.
Probably too late to make a difference, but +1 on this.  Before I adopted it, I tried half a dozen or more, and it stood far above the others in flexibility and reliability. Recent trials of others didn't change my opinion. An important part of that is an author who listens to users and tries to accommodate their needs and desires for the software.
Re: BryFi
« Reply #84 on: 16 Jan 2017, 05:36 pm »
Hi Folks,
Just an update – FINALLY – we have received AirPlay approval from Apple on our new Bryston BryFi product – please see attached PDF.
We will be able to start shipping product next week.  Thanks to those that ordered months ago and have persevered through this.
james
CanadianMaestro
Re: BryFi
« Reply #85 on: 16 Jan 2017, 05:57 pm »
Hi Folks,
james
Fascinating. Like having a BDP-Pi, DAC, and speakers all in one box?
MSRP in CAD$?
DAC chip/implementation?
Re: BryFi
« Reply #86 on: 16 Jan 2017, 07:22 pm »
MSRP in CAD$?
$1495 List
james
CanadianMaestro
Re: BryFi
« Reply #87 on: 16 Jan 2017, 10:09 pm »
Geez, I must conclude then...
- the BDP-Pi is over-priced
- the BryFi seems like a killer deal
 :scratch:
Marius
Re: BryFi
« Reply #88 on: 16 Feb 2017, 09:06 am »
HI James,
Will this Apple Airplay approval be valid for the BDP also? Since it is essentially the same software I would hope this to be the case?
Marius
Hi Folks,
james
Re: BryFi
« Reply #89 on: 16 Feb 2017, 11:14 am »
HI James,
Marius
Hi Marius
No it is totally different software in the BryFi.
james
Marius
Re: BryFi
« Reply #90 on: 16 Feb 2017, 11:36 am »
Hi Marius
james
Hi James,
Sorry for my misunderstanding. I thought the BryFi and BryPi, both built on the same Raspberry, would have had the same software as the Bdp, since the BDP and BryPi share software.
Let me ask it this way then: will you accommodate Apple AirPlay on the Bdps?
Cheers
Marius
Re: BryFi
« Reply #91 on: 16 Feb 2017, 12:09 pm »
Hi James,
Cheers
Marius
Hi
The BryFi was developed by a different software engineer so it was a completely different project. I do not think we will send the Pi in for approval.
james
CanadianMaestro
Re: BryFi
« Reply #92 on: 16 Feb 2017, 01:32 pm »
James
Maybe I missed this somewhere, but can the BryFi's music selections be controlled from the front panel? With pocket drives attached to the rear. Setting up powered ethernet access (like for my BDP-1) in every room for iDevice control is a PITA.
Re: BryFi
« Reply #93 on: 16 Feb 2017, 01:44 pm »
James
Hi
The BryFi is controlled with a phone or computer, Ipad etc.  The front has a drop down draw which allows for thumbdrives, ethernet  inout etc.to be inserted and a volume control.  But the main feature of the BryFi is that it is controlled through remote devices.  You can also have multiple units in different rooms each controlled separately.
james
CanadianMaestro
Re: BryFi
« Reply #94 on: 17 Feb 2017, 09:48 pm »
Hi
james
Hi James,
So...if I understand you right...BryFi will latch onto my home wireless router? No need to run an ethernet cord to my powerline (like I do with BDP-1)? The router should assign BryFi its own IP address wirelessly, right?
Thanks.
Pete
Re: BryFi
« Reply #95 on: 18 Feb 2017, 01:10 am »
Hi James,
Thanks.
Pete
Correct!
james
1ZIP
Re: BryFi
« Reply #96 on: 3 Mar 2017, 09:00 pm »
I went to the Bryston web site for more info on the BRYFI unit, but couldn't find it anywhere.  Are you going to add it soon?
Re: BryFi
« Reply #97 on: 3 Mar 2017, 09:42 pm »
Hi
Should be soon - we are starting to ship units this month.
james
Re: BryFi
« Reply #98 on: 29 Mar 2017, 10:24 am »
SUBJECT:  BryFi App in Google Store
March 2017
Hi Folks,
For those of you with a Bryston BryFi unit a BryFi app is now live in the Google Play Store.
Type in or copy to your browser:
https://play.google.com/store/apps/details?id=volumio.browser.BryFi2
You can also just type BryFi in the search function of Google Playstore on your Android device and it will download the application.
Please see attached PDF for more info on the Bryston BryFi.
Bryston
Re: BryFi
« Reply #99 on: 29 Mar 2017, 11:54 am »
I have a PDF of the BryFi manual  - jamestanner@bryston.com
james
