Audio/Video Gear and Systems
Open Baffle Speakers
JohnR
test open baffle
test open baffle
0 Members and 1 Guest are viewing this topic. Read 2757 times.
gils
test open baffle
22 Apr 2016, 12:26 am »
Hello everyone ,
I am new to this forum, I'm trying to make realization of U-FRAME open speaker audio system, I realized a first baffle and I wanted to have an expert opinion in this area, I ' I made a decision of his first with percussion followed by a string trio, decision is made to 3 meters with a low-end camcorder but it gives a fairly truthful even noticed it lacks precision.
U-FRAME
2 low / medium 12 "
1 compression
Your opinions will be valuable
Thank you
http://www.sendbox.fr/da99ee771fe55e57/test_open_baffle.mp4.zip
nicoch
Re: test open baffle
23 Apr 2016, 09:44 pm »
why U baffle ?
mcgsxr
Mark in Burlington, Canada
Reply #2 on:
24 Apr 2016, 06:34 pm »
I assume that you picked U baffle after considering a flat or H baffle?
gils
Reply #3 on:
24 Apr 2016, 11:07 pm »
hello ,
this is U-FRAME ( HP Europsonic TS-30 150/300 x 2 + 1 compression Browell 1 " + Pavillon Cerwin Vega
http://www.audiocircle.com/index.php?topic=121548.msg1520916#msg1520916
Europsonic TS-30/150/300
Parameter, Value, Dim
Fs, 44.62, Hz
Re, 7.91, ohms[dc]
Qt, 1.04, -
Qes, 1.13, -
Qms, 13.01, -
Mms, 26.06, grams
Rms, 0.664139, kg/s
Cms, 0.000488, m/N
Vas, 178.91, liters
Sd, 510.71, cm^2
Bl, 7.731768, Tm
ETA, 1.58, %
Lp(2.83V/1m), 94.14, dB
Le, 543.64, uH
L2, 570.57, uH
R2, 17.07, ohms
L3, 0, uH
R3, 0, ohms
Good HP for open baffle
gils
Reply #4 on:
25 Apr 2016, 02:50 am »
test is good for me , no filter , just capa 5 μF + resistor 5 Ohms on compression (105 db)
test music , my English is bad
French
http://www.sendbox.fr/7e46009e082a8d3c/test_audio_music.mp4.zip
nicoch
Reply #5 on:
25 Apr 2016, 09:24 am »
you must do a proper filter.... at last in 2.5 way ie cut the woofer on floor and live the upper goes up to horn...
gils
Reply #6 on:
1 May 2016, 11:20 pm »
hello ,
pink noise with camcorder
https://youtu.be/pEWgXQ2GG-o
gils
Reply #7 on:
9 May 2016, 12:32 pm »
test audio with crossover two way / cut 800 Hz -6 db , my cam is low de 30 Hz at 10 Khz
https://www.youtube.com/watch?v=YFwrjBhg0nk&feature=youtu.be
JohnR
test open baffle
