Sonore microRendu - Ethernet to USB output
0 Members and 1 Guest are viewing this topic. Read 22135 times.
zybar
Re: Sonore microRendu - Ethernet to USB output
« Reply #80 on: 31 May 2016, 08:58 pm »
Ho do I listen to TIDAL with this? Thank you! I need to replace my Squeezebox Touch.
I listen to Tidal via Roon.
It is integrated and works flawlessly.
I think you can also do it through JRiver.
George
plakey
« Reply #81 on: 31 May 2016, 09:12 pm »
I don't have ROON...
Tomy2Tone
« Reply #82 on: 31 May 2016, 09:22 pm »
I was a little hesitant at first to get it because of the subscription but using it with the microRendu is like cake and ice cream, they go together so nice...glitch free
zybar
« Reply #83 on: 31 May 2016, 09:24 pm »
What do you use?
George
plakey
« Reply #84 on: 31 May 2016, 09:41 pm »
I don't want another computer to run Roon.
Currently I'm looking for a one-box solution for serving files and Tidal.
Like the Aries, or one of the Aurenders. Built-in Tidal support.
But I hear this microRendu sounds amazing, so I'm curious how I can run Tidal on it.
vonnie123
« Reply #85 on: 31 May 2016, 09:51 pm »
jesusR might want to weigh in on this, but the microRendu is equipped to be used with Shair/Airplay......ipad/iphone Tidal should be workable.
You don't have to use Roon, although it pairs up great.  I can also use my microRendu with JRiver/Jremote via DLNA.
vortecjr
  • the sound has to be in concert with the music....
    • Sonore by Simple Design
« Reply #86 on: 1 Jun 2016, 01:04 am »
Have a look at this thread:
http://www.computeraudiophile.com/f26-sonore-sponsored/sonicorbiter-tidal-setup-openhome-28520/
ebag4
« Reply #87 on: 1 Jun 2016, 06:14 pm »
I have only recieved payment confirmation from PayPal.  Should I have received order confirmation from Simple Designs?
Best,
Ed
jtwrace
« Reply #88 on: 1 Jun 2016, 06:45 pm »
Best,
Ed
That's typically it until you get a shipping notice.
vortecjr
« Reply #89 on: 4 Jun 2016, 01:12 am »
Update:
The microRendu has an updated available to play native DSD with new devices. Refer here for the list of supported devices.
Sonicorbiter - Native DSD support
Please follow this upgrade procedure:
1. Go to Apps and select Software Manager
2. Now select Update
3. Wait for "Back to main menu" to appear at the bottom of the screen and ignore any Complete notices
ebag4
« Reply #90 on: 8 Jun 2016, 05:02 pm »
My microRendu is being delivered today! :thumb:
I have an Auralic Vega, will I be able to do Native DSD with this DAC (the Vega is on the list) or does the Vega have to have an update to be able to do Native DSD?  Will the microRendu have the latest firmware or will I have to update it?
Ed
jtwrace
« Reply #91 on: 8 Jun 2016, 05:08 pm »
I have an Auralic Vega, will I be able to do Native DSD with this DAC (the Vega is on the list) or do I does the Vega have to have an update to be able to do Native DSD?  Will the microRendu have the latest firmware or will I have to update it?
Ed
Yes, and even if you have to update it takes about 3 minutest from the comfort of a chair.  You don't have to do anything but look pretty.
ebag4
« Reply #92 on: 8 Jun 2016, 05:18 pm »
That presents a major challenge! :lol:
Jason, I believe you sent one or both of your Vega's back for an update, what functionality did that give you?
Ed
zybar
« Reply #93 on: 8 Jun 2016, 05:43 pm »
Ed
Great news!
It will sound very good with the iFi power supply, but you will want to get a better PS to really hear what the microRendu can do.
Enjoy.
George
jtwrace
« Reply #94 on: 8 Jun 2016, 05:52 pm »
Ed
DSD256 for the one that got updated.  My newer one already had it.
ebag4
« Reply #95 on: 9 Jun 2016, 01:05 am »
Recieved my unit, got it running without issue.  Using linn kazoo at the moment, simply because I had tried it with the Aries.  No issue playing redbook, but unable to play DSD files, they won't load at all.  I believe I played DSD files with Kazoo on the Aries.  Any ideas where I may have gone wrong?  I have the microRendu connected to the Vega with the supplied usb hard connector.  Should my DAC be indicating any other rates than these:
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000
Ed
zybar
« Reply #96 on: 9 Jun 2016, 01:10 am »
Ed
Ed,
Unfortunately, I don't have any experience with Kazoo.
I had no problems playing DSD64 with the Vega via the microRendu and Roon.
I think Jason has also been successful with JRiver.
George
ebag4
« Reply #97 on: 9 Jun 2016, 01:16 am »
Ed,
George
Thanks George, you answered one question for me, apparently there isn't any special setup for the microRendu to enable DSD play.  I have tried it with Direct DSD checked and unchecked, no joy either way.  I will try another player and see if I have any luck.
Ed
ebag4
« Reply #98 on: 10 Jun 2016, 01:21 am »
My DSD issue was Kazoo.  I loaded Kinsky and it played DSD right off the bat.  Have to use DOP as Direct DSD gives me white noise.  If I understood what Ted mentioned, I believe that may be a limitation of Minimserver.
Best,
Ed
zybar
« Reply #99 on: 10 Jun 2016, 10:26 am »
Best,
Ed
Good to hear Ed.
How's it sound?
George
