Sonore microRendu - Ethernet to USB output
0 Members and 1 Guest are viewing this topic. Read 43361 times.
firedog
Re: Sonore microRendu - Ethernet to USB output
« Reply #140 on: 30 Oct 2016, 07:08 am »
Loving my microRendu.  Using it between NAS and DAC.  Has anyone experienced improvements in sound by using LPS on router or NAS?  Any experiments using LPS on PC while using microRendu?  While I am a believer in going to extremes on the analog signal, so far the few things I have tried with the digital signal have left me unimpressed.  Before I spend money on upgrades that are pointless (or at least bring very little return for the investment) I'd like to hear from anyone who has tricked out that part of the signal chain from the PC through the router and NAS to the microRendu (including ethernet cables).
IME, if you are using the mR, the PS for the server makes little or no difference. That's part of the point, isn't it?
I won't say it makes no difference, but it certainly isn't something easy to hear, when I've tried it. I'd maybe get a decent LPS for the server, I wouldn't spend huge bucks on it. My system has good ethernet cables and a LAN filter before the mR, if that makes any difference to you.
moemoney
« Reply #141 on: 9 Nov 2016, 12:40 pm »
I have seem several topics and a video regarding the BOTW P&P ECO Power Supply, and on there web site they have it as being compatible with the microRendu, but I notice that Sonore web site list it as one of there recommended power supplies to use. Can anyone please enlighten me as to the quality of this PS.
moemoney
« Reply #142 on: 9 Nov 2016, 12:43 pm »
Sonore web site Does not list it as one of there recommended power supplies to use.
sts9fan
« Reply #143 on: 9 Nov 2016, 02:48 pm »
Does anyone know if you switch sources on a DAC does the uR need to be rebooted to be connected?  I have found this to be the case with the SOse.
jtwrace
« Reply #144 on: 9 Nov 2016, 02:57 pm »
If you mean if you pull the USB and switch dacs, yes, that's normal.
sts9fan
« Reply #145 on: 9 Nov 2016, 04:34 pm »
No, I mean pushing the source button on the DAC from USB to anpother and back.
jtwrace
« Reply #146 on: 9 Nov 2016, 05:25 pm »
When you push that button what does it disconnect?  USB hand shake?
sts9fan
« Reply #147 on: 9 Nov 2016, 05:27 pm »
seems to.  I need to unplug the SOse and plug it back in to get Roon back.
jtwrace
« Reply #148 on: 9 Nov 2016, 05:35 pm »
Makes sense then.  Whether it's electrically or physically it's doing the same thing thus requiring a reboot of the µRendu which is normal.
sts9fan
« Reply #149 on: 9 Nov 2016, 06:11 pm »
 :cry: :cry: :cry: :cry: :cry:
vortecjr
  • the sound has to be in concert with the music....
    • Sonore by Simple Design
« Reply #150 on: 23 Nov 2016, 07:32 pm »
FYI:
The black Friday sale has finished.
« Last Edit: 25 Nov 2016, 11:39 pm by vortecjr »
rodge827
« Reply #151 on: 14 Dec 2016, 01:27 pm »
I'm finally getting around to run an Ethernet cable to my listening room. There are different types and I was thinking of going shielded.
What is the best cable to use? Cat5e? Cat6a?, Cat7?
TIA
Chris
TomS
« Reply #152 on: 14 Dec 2016, 01:33 pm »
TIA
Chris
I have Blue Jeans Cat6 cables. Very nicely made, reasonably priced, available on Amazon.
https://www.bluejeanscable.com/store/data-cables/index.htm
rodge827
« Reply #153 on: 14 Dec 2016, 01:37 pm »
Thanks Tom,
Which one are you using? 5e? 6a? 7?
TomS
« Reply #154 on: 14 Dec 2016, 05:20 pm »
Thanks Tom,
Cat6
zybar
« Reply #155 on: 14 Dec 2016, 08:04 pm »
+1
George
trueaudiophile
« Reply #157 on: 2 Jan 2017, 11:21 pm »
My microRendu is up and running perfectly into my Wtred4Sound Dac2 DSDse. Usb is Asynchronous which requires 5v . Unit is a bit warm to the touch but not to bad... :duh:  This thing sounds awesome indeed!!
Great Product :thumb:
Trueaudiophile
vortecjr
« Reply #158 on: 27 Jan 2017, 11:43 pm »
John H. Darko posted a review called 'Classy! Sonore’s microRendu takes digital audio higher'
Read the review here:
http://www.digitalaudioreview.net/2017/01/classy-sonores-microrendu-takes-digital-audio-higher/
jtwrace
« Reply #159 on: 28 Jan 2017, 12:00 am »
He does great work.  Probably the best out there.
