0 Members and 1 Guest are viewing this topic. Read 37405 times.
Wow !It's sure crowded under that hood,look like 400 HP motor in a Honda Civic. That's not important, what is important is the sound coming out of under the hood.Keep the good work and thanks for the (Bad) picture.You wrote it, I am only repeating it... Guy 13
As requested by a few members on this forum, I decided that I will do a small product tour for anyone interested. Please post here if interested and what equipment you would use with the amp.
Hi, it's too bad I cannot register,because soon I will be back on planet Vietnamwhere my audio stuff is.Your amplifier would be a good match for my Omega 7F OBDP set up.I have now a Decware SE84C+Anxious to read the reviews of AudioCircle members.When I buy something, I always try to buy Canadian, then second choice US made, then all the other onesand if I have no other choice, then Made in China.Of course, prices always have something to do in the decision.Thanks.Guy 13
It's too bad you won't be able to join in the tour. If you happen to be in Calgary sometime before you leave, you can always come try it out!The USD to CAD exchange rate doesn't hurt either, if buying from the states.To Everyone who has or will respond today: I will be contacting everyone at the end of the day to collect info for the tour by private message.
Usually this done with a transformer, which is quite an expensive option.What if it was a tube rollable preamp using any of these: 12AU7, 12AT7 or 12AX7 (your choice) for different amounts of gain?Or would something that uses a volume pot and a high-medium-low gain switch be more to your liking? Or something else entirely?
How possible is it to put a pre amp out on this integrated?
A preamp out is possible, but will not likely happen, though I will be releasing a tube preamp with multiple outputs in a few months time (hopefully).
