Bryston announcing new SST3 amps
0 Members and 1 Guest are viewing this topic. Read 227545 times.
Grit
  • - Garrett
Re: Bryston announcing new SST3 amps
« Reply #940 on: 4 Oct 2017, 11:27 am »
Oh yes! If you could find a way to lower the profile of the chassis, that'd be the perfect center channel option! Or, better yet, 3 of them for the front 3 speakers!
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #941 on: 10 Nov 2017, 07:15 pm »
SUBJECT: Bryston 7B Cubed Mono Amplifiers
November 2017
Hi Folks,
Please see the link below for a new review from Inner Ear Magazine on our new 7B Cubed Mono Amplifiers
https://www.innerearmag.com/
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
« Reply #942 on: 10 Nov 2017, 11:06 pm »
Very nice review
I had the 4b3 it was very nice,but i would clip the amp
I than purchased the 7b3,very nice
Elizabeth
  • Love is all there is....
« Reply #943 on: 10 Nov 2017, 11:33 pm »
James..
For either a Magnepan 3.6 or 3.7i or... maybe 20.7..
Would a pair of Bryston 7B3
or.. a 14B3 be better.
with no consideration for location, or two powercords..
(though if a six inch speaker cable pair with the 7's vs a five foot pair for the 14.. matters??)
I currently own the Bryston 4BSST² and Magnepan 3.6
With some fantasies of upgrading..
So the question is 14B3 or pair of 7B3 ???
My main love is HF definition, midrange clarity, no interest in 'big' bass. good bass definition though is fine.
« Reply #944 on: 10 Nov 2017, 11:41 pm »
James..
Hi Elizabeth
7B's for sure - there are really too advantages - short speaker cables (makes a difference) and more power supply capacitance (double what the 14B has) for those transients on the Maggies.
Have you seen the new Magnepan 30's?
james
« Last Edit: 11 Nov 2017, 09:00 am by James Tanner »
john1970
« Reply #945 on: 10 Nov 2017, 11:44 pm »
Hi Elizabeth,
Just recently I went through the same decision you did.  A single 14B3 vs. a pair of 7B3.  At the end of the day I went with the pair of 7B3 for the following reasons:
1) Each 7B3 has twice the capacitance relative to a single channel of the 14B3 which provides better stability into high current loads.
2) The 14B3 is heavy to lift (90+ lbs) while each 7B3 weighs 55 lbs.  I can easily lift 55 lbs, but 90+ lbs is too much to move and position.
Good luck with your decision.  You can not go wrong either way.
John
Elizabeth
« Reply #946 on: 11 Nov 2017, 06:08 pm »
Hi Elizabeth
james
$30,000 for the 30.7 is both the 20.7 and the 7B3 with spare change..!  And the four part speakers would be hard to squeeze into my apartment!
And thanks for the advice on the 7B3 vs 14B3.
« Reply #947 on: 11 Nov 2017, 06:53 pm »
HI
I had Tympani 4A's a while back and they were terrific - but you need a BIG room and a BIG budget  :green:
james
« Reply #948 on: 17 Nov 2017, 09:35 am »
New B17 Cubed Preamp with 14B Cubed amplifier.
TJ-Sully
« Reply #949 on: 18 Nov 2017, 03:50 am »
 Looks awesome James!  :thumb:
TJ-Sully
« Reply #950 on: 18 Nov 2017, 03:54 am »
going old school here...with 4B2, etc....on my new custom built stand - white birch with walnut posts! made in NB baby :)
OTM
« Reply #951 on: 18 Nov 2017, 12:25 pm »
Nice work
CanadianMaestro
  • Skepticism is the engine of true progress
« Reply #952 on: 18 Nov 2017, 02:34 pm »
Beautiful. Sparse, simple, nothing fancy.  :thumb:
TJ-Sully
« Reply #953 on: 18 Nov 2017, 03:57 pm »
thanks fellas! :thumb:
« Reply #954 on: 12 Dec 2017, 04:46 pm »
Hi Folks,
Link on our website to the new 21B Amplifier.
http://www.bryston.com/products/active/21B-3.html
james
« Reply #955 on: 18 Dec 2017, 12:44 pm »
TJ-Sully
« Reply #956 on: 18 Dec 2017, 11:20 pm »
Congrats James!
Given all the new Bryston products over the past 5 years or so - what are you most proud of James?
TJ
« Reply #957 on: 18 Dec 2017, 11:30 pm »
Congrats James!
TJ
Hi TJ
The Active speakers - it really takes performance to a new level  :thumb:
james
TJ-Sully
« Reply #958 on: 18 Dec 2017, 11:46 pm »
Right on. I can't wait to give them a listen someday. Any distributors in the Maritimes James?
also, wondering about the connection between PMC and Bryston these days. I see the PMC website shows a beauty Bryston preamp and CD player.  Just curious!
« Reply #959 on: 19 Dec 2017, 02:44 am »
PMC is our distributor in the UK and uses our amplifiers and crossovers in their large active systems.
james
